1 - 19 of 19 Posts
Let me start by saying; as I post this... I am already changing things on the install.
But, that will probably be a never-ending venture; so here's where I'm at so far:
First off, the install subject: BMW X6-M
• 570 horsepower
• Twin-turbocharged 4.4 litre V8
• Zero to 60 in 3.8 seconds
• Will pull a full G in the corners
This thing is an absolute monster...
There are some really nice professional installs posted, and I admire the level of detail put into these.
But, I am just some dude in his (dimly lit) garage, working with everyday tools.
The cuts aren't fancy. There's no 3D printing. And most of the material came from Home Depot or Amazon.
The equipment is all the same as what I had in my previous vehicle:
OEM Head Unit into mObridge DA3 into Helix DSP-Pro Mk II
Amplification: MMATS HiFi-6150D and MMATS HiFi-4250D
Front Stage: Sinfoni Tempo 10, Dynaudio Esotar 430, Audio-Development W800-NEO
Rear Fill: Audiofrog GB10, Audiofrog GB40, Audiofrog GB410 (passive crossover)
Subwoofer: Audiofrog GB10D2
As with all my installs, I have two basic criteria:
1. Sound Quality
2. Stealth Installation
Let's start with the install location. Under the rear floor is a hidden cargo hatch, with a fair bit of room:
With the carpeted floor removed, we have a lot of room to work with:
Covered the floor with sound deadener, and also up the sides (did the sides later in the process):
Next, it's time to cut some 3/4" MDF, to make the sub enclosure and amp rack:
Construction adhesive and brad nails... this thing will never come apart:
Audiofrog specs 0.6 cu.ft. for a sealed enclosure on this sub. My enclosure nets 0.67 cu.ft. after the displacement of the sub.
Test fit, with the bottom layer of the amp rack added:
Now, to start on the power cables...
I've always used Knukonceptz cables and power distribution block. They just work good.
Strip the jacketing back about 5/8", and slip it through the gland:
Bend the wires back over the sheath:
Thread it in with your fingers, to ensure you don't cross-thread:
Then, wrench that bad boy down tight:
Same process with the positive cable:
Here's the distribution block, mounted on the bottom of the amp rack.
Everything is zip-tied and screwed down to the board. 0awg in / 4awg out.
Fused positive on one side (2 X 80amp fuses), and solid negative on the other.
The smaller separate inline holder is a 5amp to the DSP.
I also mounted the Helix DSP onto the bottom layer of the amp rack, and ran the RCA's to it:
Carpeted the sub enclosure, and added some Poly-Fil:
12awg. Knukonceptz speaker cable for the sub:
Sub is in:
Time to bolt-down the lower part of the amp rack... what a rats nest:
But it cleans up nicely...
Now for the top layer of the amp rack:
Pulled the RCA's from the Helix and connected them to the amps:
Again, everything is zip-tied and screwed down secure:
RCA's are connected and Power Cables are connected to the amps:
Speaker cables are all pulled through the vehicle, and connected to the amps:
(this is definitely the hardest part of the entire job)
Time to bring power to the system...
Strip back the 0awg. ground cable:
Slip a ring terminal over it:
And crimp that baby down!
Bolt it down to the OEM grounding lug:
Same process for the 0awg. positive battery cable:
BMW uses a MOST fiber optic system for virtually everything in the car... including the audio system:
In order to tap into that fiber optic network, I used a mObridge DA3.
The DA3 has a built-in DSP, but I bypass that and just use it to tap into the MOST fiber optic.
Helix also makes a similar unit: # SDMI25. The Helix does not have a DSP, just a Toslink output.
Just configuring the mObridge to work with the vehicle, and bypass the internal DSP.
It sends a full-range, completely pure flat signal to the Helix DSP-Pro:
Now, onto the door speakers... unfortunately, I got focused on doing the work, and forgot to take a bunch of pictures.
Here's the front door skin removed:
Not much to see here... except that I needed to pull half of the lower dash out, to run the speaker cables through the Molex, into the doors:
(what a total pain in the ass, pulling cables through an already packed Molex)
Cables pulled through:
The OEM speakers aren't total garbage... but they're far from great:
This is one of the current changes...
I used MDF as the base speaker ring, but just today I went and bought a piece of HDPE plastic.
It'll annoy me, knowing that MDF might swell-up from humidity and temperature changes.
I'll be pulling the door skins off again, and replacing that MDF with HDPE:
Tweeters are mounted in the OEM sail panels. Had to cut it a bit to make the Tempo 10's fit:
Doors all sealed up with sound deadener:
And for the final ingredient... to replace these weak under-seat woofers:
Somehow, they produce a decent amount of midbass... but I'm sure I'd blow them up, if I attached them to my MMATS 4250:
Replacing them with this... Audio-Development W800-NEO:
Put some sound deadener in the base of the under-seat enclosure:
It is open vented into the side pillars of the vehicle.
Cut some speaker rings / extenders out of HDPE plastic:
Cut the ridiculously long speaker posts down with a hacksaw:
And soldered the speaker wires to them:
Then mounted them into the OEM floor boxes:
That's about it...
Put everything back together; door panels back on, seats bolted back down, dash and trim put back in place.
As mentioned; I am already going to change a few things... just because I'm a sucker for 'the latest and greatest':
1. The mObridge DA3 is getting swapped for the newly released model: DA.G2-PRO. I expect it to arrive early next week.
2. The Helix DSP-Pro will be getting replaced with the new DSP-Ultra, when it becomes available.
The MMATS 6150 powers: Front Tweeters (150W each), Front Midrange (150W each), Rear Fill (150W passive per side).
The MMATS 4250 powers: Underseat Midbass (250W each), Subwoofer (500W bridged).
I did a bit of basic tuning and time alignment. Just enough to make it sound decent. Actually, it sounds really good!
But until I get the new components (mObridge and Helix DSP), I'm not going to spend hours tuning it.
I'll do it properly, once everything is installed.
Total install time: about 30 hours.
I haven't posted here in a while, but this popped up on my TaT app. Very nice machine and build to go with it, but you already know that ;)
Sent from my Pixel 2 XL using Tapatalk
Beautiful work and very helpful as I plan my 2016 X6 F16. The X6M is a beast. Our Xdrive 35i is no slouch but it is really my wife's car or I might have been tempted to step up to the 8 cylinder M. I did add an MPPK tune though.
I’ll likely have a few component differences and only do some of the work myself and have a professional installer do the hard stuff. Wish I had your experience and skill but I don’t want to do my first upgrade alone on a relatively expensive car.
Thanks for all your help so far.
If you tune the helix with auto eq and save the files you can then re import the eq files to the ultra as well ;)
Nice simple system you have there 👍🏼 Like it!
Having those under seat woofers is fantastic - door woofers in my experience sound like ass no matter how much dynamat you use. Are those woofers run infiinite baffle then ? at some point the backside vents into a large frame rail ?
Ya, the floor boxes vent into the side pillars.
Happy with the single GB10 sub?
It's a great sounding sub. Fast and precise.
It doesn't produce huge booming bass. But fills the low end nicely.
If a guy was after 'big bass', then I would recommend a GB12.
Discussion Starter #10 (Edited)
Couple updates (per my original post):
The new mObridge DA-G2.PRO arrived this morning.
I removed the DA3 and replaced it with the new unit... sounds the same.
I pulled the door skins off, and replaced the MDF speaker rings with HDPE ones:
The new mObridge DA.G2-PRO has 10 output channels, which is what I needed (9 actually).
It also has a new algorythm to upmix a center channel (which I'm not using - but maybe in the future).
These are the two main advantages over my prior mObridge DA3.
I spent about 4 hours tuning the new mObridge DA.G2-PRO unit today.
It's a bit more work than my previous Helix DSP-Pro, but I believe I have got it sounding just as good.
The advantage with the Helix, is that it has a built-in RTA, and can auto-tune (helps to get the baseline EQ'ing done).
The mObridge has none of this, so I needed to do RTA measurtements with REW, and then manually adjust the EQ settings for each (and every) speaker.
My original plan was to also get a new Helix DSP-Ultra (when it is released)... but I'm not so sure now. After properly tuning; the mObridge sounds REALLY good.
Discussion Starter #13 (Edited)
Changed a few more things...
  1. I swapped the mObridge unit for a Helix SDMI25. Doesn't make any difference... just my OCD wanting it to match the new Helix DSP.
  2. I swapped the Helix DSP-Pro II for a moBridge DA-G2.PRO... then swapped that for a new Helix DSP-Ultra!
260355
260356
The DSP-Ultra is incredible!
In my opinion; it is a definite (and noticable) upgrade from the DSP-Pro II.
You can run it in 'basic' mode, which doesn't really offer any benefit over the DSP-Pro II (aside from 12 channels).
Or, you can switch on the 'Virtual Channel Processing', and suddenly you are open to a pile of new stuff!
I have dialed-in the Augmented Bass Processing, and it is something else!
Still playing with the software.
I'd say the tuning was 70% done with the built-in RTA and Autotune feature. The rest was done 'by ear' to suit my taste.
Still tinkering with the fine tuning... but I'm close to being satisfied.
Awesome work Jimmy.
It takes confidence to disassemble and work on a car that expensive. Hell, I had some sleepless nights when I was working on my $16k used Camry :) .
Looking forward to seeing how the “ultra” works out for you. If I could change one part of my system today, it’d definitely be my DSP.
Congrats on the new car and new install. It looks great!
Makes me want to buy the Ultra, but honestly I’m not proficient enough that I feel I would notice.
Sent from my iPad using Tapatalk
Discussion Starter #16
I bet you'd notice...
As mentioned; if you just use it in standard mode, then there's no appreciable difference, other than 12 channels out versus 10.
But if you put it into 'Virtual Channel Processing' mode... then it's a whole new world.
I've played with a few of the Virtual options, but haven't mastered any of them except for the Augmented Bass Processing.
The bass is substantially better on shitty old 80's rock recordings, and WAY MORE DEFINED on lower volume listening.
It's dynamic, so it automatically adjusts depending on what information the recording has, and what volume level you're listening at.
This alone made the Ultra 'worth it' for me...
Darn now of course I’m now looking for a vendor for this. I’m feeling my current Helix MKII will be up for sale.
Discussion Starter #18
It's been wicked cold here, the past few weeks...
So, when I first installed the Helix SDMI25 and DSP-Ultra; I kinda did a quick hatchet job.
It was just too damn cold out, and I wanted to get them installed... as fast as possible, before I froze.
This week, it warmend up, substantially.
So I went out to the garage, ripped all the wiring out, and spent the past 6 hours installing them properly.
(cables pulled evenly, and zip-tied, and strapped down to the mounting board)
Also, a few weeks back; I started using ferrules... since then, I'm junked on them!
I've been putting ferrules on everything!
Power Connectors:
260497
Speaker Connectors:
260498
Blank Ferrules (with heat shrink) for 4awg Power:
260499
I got the SDMI25 installed neatly. Mounted where the OEM amplifier was:
260501
Re-did all the wiring to/from the DSP-Ultra:
260509
And ran new Stinger 8000 Series RCA Cables to the amps:
260507
Finished Product - Everything Is Strapped Down Secure:
260508
Looking good! I just swapped out Stinger 8000 for the 9000 series. Found a deal almost too good to believe. Someone in Australia had 3 pair of 6ft 9000's listed on eBay for $120 shipped.
1 - 19 of 19 Posts
