JL 500/1
Functionality is 10/10 and appearance is 7/10. I'm giving it a low rating because it does have some scuffs and scratches but it's really not terrible, I'd say the worst is the side shot where the black has been rubbed off but that's able to be touched up with a little paint if someone wanted to, really not that difficult.
Features:
Differential-Balanced Input Topology: (1 pair of Inputs)
On-board Crossover: fully variable (40Hz - 200Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
Bass EQ: parametric with variable boost up to 15dB and Remote Bass Control (optional)
Infrasonic Filter: fully-variable 24dB/octave from 15-60Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual Mono Speaker output connections: accepts up to 8ga. wire
+12V and Ground connections: accepts up to 4ga. wire
Specifications:
Rated Power: 500W RMS @ 1.5 ohm-4 ohm
(11V-14.5V)
THD at Rated Power: <0.05% @ 4 ohm
S/N Ratio: >95dB below rated power
Frequency Response: 5 Hz-500Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm per channel/50 Hz
Input Range: switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
$200 shipped, insured and includes paypal fees.
Included in total price.
Pictures: -
