Brand new in original box, includes all accessories and paperwork. Mint condition, never used or installed.
Specifications
Specifications
- Frequency Response: 12 Hz - 21 kHz (+0, -1dB)
- Input Voltage Range (at RCA inputs):200mV - 16V RMS
- Signal-to-Noise Ratio:
- Analog Inputs (20Hz - 20kHz noise bandwidth): 99dB (rated power); 80dB (1 W)
- Digital Inputs (20Hz - 20kHz noise bandwidth): 101dB (rated power); 82dB (1 W)
- Damping Factor: >100dB / 50 Hz @ 4Ω; >50dB / 50 Hz @ 2Ω
- Standby Current Draw: 2.4 mA
- Dimensions (WxHxD): 11.297" x 2.081" x 6.692"
- Weight: 6.5 pounds
- Featured in our article: Best multi-channel car amplifiers for 2022
- 8-channel car amplifier
- 75 watts RMS x 8 at 4 ohms (100 watts RMS x 8 at 2 ohms)
- 200 watts RMS x 4 bridged at 4 ohms
- Class D amplifier design with NexD2™ switching amp technology
- 24-bit 96 kHz digital processing
- DSP adjustments and settings made with JL Audio's TüN app (PC and Mac) via USB, via Bluetooth (tablets and phones) with BTC Bluetooth option
- 3 Project Levels of tuning: Basic, Advanced, Expert
- input routing and mixing
- adjustable gain controls with clip indication
- fully adjustable high-pass, low-pass, and bandpass filters
- selectable filter slopes (6, 12, 18, 24, 30, 36, 42, 48 dB/octave)
- 10-band EQ (graphic in Basic, parametric in Advanced and Expert modes)
- phase and polarity control
- time alignment in 0.01 ms (1/8") increments
- differential-balanced inputs eliminate noise coming from your vehicle's electrical system
- preamp and speaker-level inputs (speaker wire to RCA adapterrequired for speaker-level input)
- high-level inputs — up to 16 volts RMS (about 60 watts)
- DC offset or signal sensing auto turn-on eliminates need for remote lead
- 2-channel digital input and output (S/PDIF: up to 24-bit 192 kHz in, 24-bit 96 kHz out)
- 2-channel analog preamp output (4V RMS)
- JLid™ connections for optional Network Hub, Bluetooth Communicator, and Digital Remote Control
- USB connection for device running TüN app (6-foot cable included)
- wiring, fuse, and hardware not included with amplifier
- 4-gauge power and ground leads and an 80-amp fuse recommended
- 11-5/16"W x 2-1/8"H x 6-3/4"D
