1 - 7 of 7 Posts
I am running an Alpine cda-9887 with active crossovers to a JL Audio HD900/5.
*My subwoofer channel has been giving me issues. it appears that output fluctuates between 31.3-31.6 volts occasionally, sometimes as high as 32.2 volts.
I may just be paranoid, but I remember feeling a pop once while adjusting the the input sensitivity(gain).
Before i send my 900.5 back to JL, I was wondering if my crossover could have anything to do with this.
I just realized the Alpine cda-9887 I am running with imprint utilizes an active crossover on the sub channel when using Imprint.
**I had issues with the crossover point Imprint was using so I enabled my crossover on the amplifier.
***I assume this would be considering running 2 crossovers which I remember being unwise. Could this be the source of my problem?
Thanks in advance for any help,
PS: I am running a sealed 12w6v2 (2ohm load)
Discussion Starter #2
Bump! Does anyone know the the cost of out of warranty repair for the JL HD900/5?
Purchased it from Sonicelectronix. They will not honor my warranty because I'm a year past the billing date, but not past the shipping date... I still have 3 days!!!
So remember that sonicelectronix.com does not have strong business morals or ethics!
I do not believe multiple crossovers would cause the fluctuation, unless your test tone frequency is near the crossover frequency - but even then I don't think it would cause the fluctuation.
I notice that my 900/5 does not produce a steady reading unless you get the DMM probes set just right. I usually insert them into the plug and then tighten the screw as if it were speaker wire.
Not sure that helps, just throwing those thoughts out there.
This is another interesting component, I lost one of those tiny little metal cylinders from inside one of the comp speaker terminals. After looking around for and hour and nearly pulling out my entire interior I could not locate it. I haven't noticed much of a difference though Imprint has been favoring one side of my car anyway so I guess It could be a factor I haven't grasped yet.
I've been taking my readings from the end of the speaker lead with the sub disconnected. A 50hz sine wave is pretty close to my 83hz crossover and who knows what kind of slope/x-over Imprint throws under that.
I'm going to get a full signal (200hz on cda-9887) reading of the sub channel with a 50hz sine and the Imprint turned off, just using the amp's x-over.
I just realized I haven't taken any volt readings with Imprint off since noticing the fluctuation, that would at least rule out the crossover dilemma.
I guess I'll do that in the parking lot of my local JL dealer who should be able to give me a repair price if the amp is truly the problem's source. I guess i'll inquire about the speaker terminal part number and price as well.
Thanks for the reply Sdevante, what are you running as an HU with your 900.5?
Also, I recently had my B+ cable replaced in my car, which still seem to be fine.
I've been using the same ground in my car for years without a problem, its a seat bolt, but ground down to metal on both sides.
Sure I get a little dimming when banging full vol @ highway speeds.
The HD 900/5 shouldn't require a big 3 upgrade, should it?
I'm running a JVC Kameleon KD-AVX44 dvd player into an Audiocontrol 6xs crossover, then into the HD900/5.
I don't think that amp should require a big three upgrade b/c its only a 60 amp fuse, which is not (relatively) a lot of current.
Also, you can occasionally catch those speaker plugs on eBay for about $20 I think.
the cda-9887 definitely has an an active crossover on the sub channel.
I am going to send a defeated, full signal to the amp and take a reading of the 50hz sine on my lunch break.
This should be the deciding factor in weather or not my amplifier is malfunctioning.
1 - 7 of 7 Posts
