These were auditioned in the OEM (read: **** ass) midbass location in the rear of the doors in my 08 VW GTI.
The doors are pretty well deadened on the outer skin, the inner skin and the door panel.
The baffles are 2 layers of 3/4" Birch ply and 1 layer of 1/2" Birch ply for 2" total.
For now, power is from a Zapco DC Ref 750.2 in stereo at 4 Ohms stereo.
The HU is an OEM VW RNS-510 through a Navone LOC to the Symbilink transmitters.
The JLs, out of the box, are hands down better sounding. Like the difference between home theater an home audio. HT will do music well, HA does it better. Better resolution, more detail, more musical. It reminded me of the difference between a Mag v4 and a DIYMA R12 with the extra bottom end the Mag has over the DIYMA. The Dayton is like the Mag and the JL is like the JL. The JL has a faster attack and decay and tonally it's flatter out of the box. With no EQ the Dayton's are more "fun" but the JLs are more "correct."
The JLs are however, less efficient.
If it wasn't for the fact that my car kills midbass when in motion I'd stick with the JLs. Hell, I might put them back in anyway and try them for some more extended listening. Maybe the efficiency difference won't matter so much.
Size-wise, the mounting depth is pretty much identical. We're talking less than a 1/16" difference. The ZR800 is a smaller framed driver so it'll fit in more places. Because of the smaller frame the cone is a little smaller but it also has MUCH more excursion. At first this worried be but it also has much more motor so the extra movement does seem to be well controlled.
I listened to a number of different tracks in a number of genres but some examples are:
Dire Straights - Money for Nothing
Earth, Wind, and Fire - Getaway
Lil Wayne - Go DJ
Colbie Caillat - One Fine Wire
Michael Jackson - PYT
In every case with REAL drums the JL sounded more like real drums. The Datyons had a bit too much bottom. Even snares were very full sounding. Again, the JLs seemed faster and more tonally accurate compared to the Dayton. Not that the Dayton is bad by any stretch of the imagination, the JL is just better. Think of the JL like a Dyn...but with balls.
I'm kind of rambling now so I'll sum it up like this, if you want to go subless, run the Daytons. I have them all the way down to 30Hz with a -6dB slope and they didn't even bat an eye. They easily played 40Hz notes, and with authority I might add. My first thought with the Daytons was "Maybe I should have waited on putting subs in." Which also left me thinking "The midbass/sub transition is going to be VERY fat."
So to sum everything up,
Pros:
JL - more tonally accurate, a little easier to squeeze into some cars, comes with a grill
Dayton - more efficient, more robust bottom end, spring loaded push terminals, plays low and loud, can be used in a 2-way with a large format tweeter or horns, price
Cons:
JL - smaller cone, solder tabs, price, is pretty useless over maybe 400-600Hz,
Dayton - sounds more like a sub than a midbass, no grill included
I know this is kind of all over the place so feel free to ask any questions you might have. I think I've decided to toss the JLs back in and give them a week or two with the sub playing and see how I like them. I'll revisit this thread when I have more findings.
Lil Wayne - Go DJ
Pros:
Cons:
