What should I do?
1 - 5 of 5 Posts
Normally I do not need any help. But in this case I just can not decide how I want to go on this.
I will be using 4 Pioneer Premier 10" TS-W2502D2. I already have them sitting around new in the box. I have about 3000 watts of old school Infinity power to throw at them. They will be the sub stage in a 4 way set up. So playing somewhere around 70Hz and down only. The mid bass will have 400-600 watts at its disposal so they should have no problem keeping up.
But here is my dilemma. I can not deiced if I want to go ported, sealed, or Infinite baffle. Space is not really a problem so having 4 boxes that are basically 20" x 20" x 11.5" is not a big deal. That box will leave me tuned between 24.07Hz and 26.48Hz depending on speaker displacement. (Why have they stopped listing this spec?) Sealed I looked at 1ft^3 then tried it at 600ft^3 and there was not much of a change. So that then made me consider infinite baffle and putting the back wave outside under the vehicle.
Now we know the pros and cons of each method. And this is where I just can not make up my mind.
I might remove a window and make a baffle to test how 1 of them does IB. There is a nice spot on the floor I can cut out and recess to make the baffle. The elements will not be an issue if I go the IB route.
Being there is not a conceived large difference I do not think I will do the small sealed box as of writing this. So I am down to ported or IB.
So what do you think I should do? Maybe you can sway me 1 way or another. I promise there will be a build thread for this system and it will not disappoint when I am finished.
Here is the win ISD.
Subs in question if you want to see them.
If you want no low-end go sealed. But IMO if you go ported, you should go for a curve that doesn't peak much, maybe 1-2db tops. The flatter the better, unless you don't care about sound quality and only care about spl.
and what are we supposed to actually DO for you???
Make up your mind?
I want both actually. Under normal conditions the subs will not be turned up very high. You can adjust that in the HU an old 8v Eclipse. I have kids that will be in it a lot of the time. But I do still like being a bass head from time to time if I am alone.
1 - 5 of 5 Posts
