I have a Hyundai Veloster with a crummy Infinity OEM system. I wanted to play around with some low budget upgrades, so I bought a $400 JBL 8ch DSP/amp. This is 1channel short of discretely powering everything I need. I want to make the factory speakers sound the best they can and upgrade in a year or two.
-Fronts are 2ohm 6.5s on the lower doors. 1" Tweeters in dash (dash isn't crazy long)
-center is a 2ohm 2inch
-rears are 3.5ohm full range, up high.
-I plan to use channels 7+8 to power the factory 6.5" sub.
Would it be better to
A) delete the center channel, run Rears and active fronts on DSP
B) run the fronts passive
C) run active fronts + center and keep the rears running on the factory amp (fading all the way to the front unless I have passengers)
