1 - 2 of 2 Posts
Good day,
I am hoping to get some sound advice on the system I am starting to build.
I will be running 6 Kicker 12L7's powered by 3 PPI PC2350's.
My question is which model 12L7 should I be purchasing. I have seen 2ohms and 4 ohm models.
Any help would be appreciated.
ugg, i want those freakin amps, bad........lol, anyways, first, you need to make sure you have the power to feed the amps, or will. if you can support the 4500wrms, then go with d4ohm models, and then you can run each amp either 2ohm sterio (one sub per side, or basically 2 coils per side, or 4ohm stereo (4ohms bridge, which would be series-parellel 2-subs) to do this, you are looking at 500a+ of alternator power (i wouldn't go much below 450 if you plan on playing it for a min or so cont at high volume) and i would suggest at least 4 good aux batteries. if you cannot do this, then i would suggest d2, so you can run the amps at 4ohm stereo, in which case, i woould still recomond going with over 200a single h.o. alternator, but you cannot get the amps to their full potential running a pair of d2's per amp, because they will not safely do 1ohm stereo/2ohm bridge...
1 - 2 of 2 Posts
