Good Day Everyone, I will be attempting my first enclosure build, I am excited to see how well this goes, but first a little introduction as to how I came to this decision to build a box, I bought this sub along with a box off Amazon.
The cutout was too big when it arrived if I remember correctly something wasn't right, had to return it. Dissapointment the first feeling I felt, them found another box online never bought it to big for the car.So I said fine I just build my own. Expecting everything to be plug and play, never worked out for me, so I sat around about a month thinking what would be my next step to do with this nice Kicker sub I was once excited to just put in and play and now it's completely useless at least until it gets a proper home. So I decided to build my own. After months of research with the limited time I have from working full time, I am finally about to get building so I am happy and pretty dang proud of myself, for pushing though this far so far, and in my opinion this enclosure will be better than any prefab I could've brought online and sound better too hopefully.
(Forgot to mention up there 15s love thier space and didn't mind giving up my whole trunk, and wish I knew this before, If I knew this box was going to be long research project I would've still done it.
The box is going to be 8.01³ Gross and 6.41³ Net.
1.6 Cubes are displacements including the port, speaker bracing, plexiglass, and 45s using 3/4 MDF which brings my net volume of 6.41 back to the gross volume of 8.01.
Outer dimensions of the box will be 38x20.75x22, Will be doubled baffled.
Inner Dimensions will be 36.5x18.5x20.5
This enclosure will have a plexiglass (cast acrylic) viewing window with a chamfered 45° degree leading to to the window and the window will be below the wood with the chamfer wrapped with black vinyl and gray carpet for the outside of the box.
Dual Voice Coil 4 OHM Sub will be powered by a 1200 watt Kicker AMP wired down to 2 OHM.
Pic 2 is the transfer function of the box without filters, Thanks for reading.
