Hello all! This is my first post here so I'm hoping I can get some help before I finally just go into an audio shop. My setup is an Alpine CDE-172BT with the KTP445A. My problem is low volume... when turned all the way up(35) I can barely hear the audio like a very quiet whisper. If I connect the harness directly to my HU, bypassing the KTP445A, my audio is totally normal. But as soon as I connect it up to the in-line-amp I got this low volume issue. My car is a 2007 Grand Caravan without the factory amp its the base model. Any ideas on what could be causing this issue? My harness is wired color to color, the big yellow is connected directly to the battery, and my black wire is grounded. I've tested the ground and constant power connections and both are good at 12v. My guess would be the amp isn't turning on... The blue wire and blue/white wires are all connected. If someone could please help me it would be much appreciated!
