Hi all, can someone help with a amp set up.
I got a lc4.800 amp and taking high level input from factory signal into 2 input channels (plugged this in the front channels on amp). There is nothing else plugged into the the 4 input channels (2 channel front high and 2 channel rear)
The outputs are the following:
2 channels to underseat subs
2 channels bridged to trunk sub.
Do i need to press the sum function or do I keep seperate. I can't hear much difference between the two but want to get it right.
In essence it's a 2 channel input, and 3 channel output.
But not sure if I need to press the sum function. Does the sum function only come to into play if plug in other input channels?
This is what it says on the manual but a bit confused if only have 2 input feeding 3 channels
Front/Rear Bus Sum – This sums the front and rear inputs togeth- er. So two inputs (L/R) can feed four outputs (2L/2R
