1 - 10 of 10 Posts
Super Moderator
If you have any good thread links post them and I will add them to the list. Covering topics from super noob to technically detailed.
Most Important
Searching the forums effectively
http://www.diymobileaudio.com/forum/new-member-introduction/32613-diyma-message.html
12v Glossary
Crossovers, Gains and Tuning
http://www.diymobileaudio.com/forum...-our-members/7160-basic-guide-crossovers.html
http://www.diymobileaudio.com/forum...ers/51435-setting-gains-w-o-oscilloscope.html
http://www.diymobileaudio.com/forum...bers/33149-mini-tuning-guide-active-user.html
http://www.diymobileaudio.com/forum...rs/33740-simple-way-tune-courtesy-cmusic.html
http://www.diymobileaudio.com/forum...gnment-using-only-noise-tracks-your-ears.html
More power to clean up midbass? Also, some crackling as I increase volume.
Time Alignment and driver seperation????
http://www.diymobileaudio.com/forum...-how-eq-better-sound-staging-without-rta.html
http://www.diymobileaudio.com/forum...ow-make-your-rta-$100-dlls.html?highlight=rta
http://www.diymobileaudio.com/forum...uerta-calibration-tutorial.html?highlight=rta
The RTA thread (Use. Not how to build one)
Flat Response?
http://www.diymobileaudio.com/forum...iscussion/131029-target-curve-comparison.html
http://www.diymobileaudio.com/forum...120190-does-anyone-understand-cabin-gain.html
Speaker specs. and Choosing speakers
Picking driver and crossover points
http://www.diymobileaudio.com/forum...d-our-members/31-real-deal-8-ohm-drivers.html
http://www.diymobileaudio.com/forum...s/69110-comprehensive-front-stage-set-up.html
$250 2 Way vs $250 3 Way
'Pro Audio' setup for SQ
'THE' Passive SQ System
QMS, QES, QTS, What makes up a speaker?
Attenuating a Tweeter
Midbass
midbass arrays revisited
http://www.diymobileaudio.com/forum...ight-6-5-midbass-drivers-any-suggestions.html
http://www.diymobileaudio.com/forum...r/128953-looking-specific-midbass-advice.html
http://www.diymobileaudio.com/forum...ussion/41581-rear-mounted-midbass-anyone.html
http://www.diymobileaudio.com/forum...-audio-discussion/67661-midbass-rear-car.html
Rear Fill Speakers
http://www.diymobileaudio.com/forum...uipment-my-car/9806-rear-fill-do-you-use.html
Let's talk about "proper" rear speaker use.
Hey Werewolf, confusion about L-R...
http://www.diymobileaudio.com/forum/how-articles-provided-our-members/81191-rear-fill-speakers.html
Subwoofer specs. and Choosing Subwoofers
http://www.diymobileaudio.com/forum...ssion/148354-somethings-up-dbs-cone-area.html
highish sensitivity sub with low vas/Qts?
given that 'cabin gain' is a reality, do we need a low fs?
http://www.diymobileaudio.com/forum...a/87371-fast-bass-slow-bass-myth-vs-fact.html
http://www.diymobileaudio.com/forum...ma/93666-larger-subwoofers-=-flabby-bass.html
http://www.diymobileaudio.com/forum...myth-more-cone-area-=-deeper-slower-bass.html
Underpowering a sub?
http://www.diymobileaudio.com/forum...stry-dogma/113166-designed-sealed-ported.html
http://www.diymobileaudio.com/forum...sion/103619-12w6v2-good-rock-metal-music.html
http://www.diymobileaudio.com/forum...on/117694-difference-between-sq-spl-subs.html
http://www.diymobileaudio.com/forum...sion/102122-dual-10-vs-single-12-subs-sq.html
Install related
on axis vs. off axis
On Axis vs Off Axis ???
http://www.diymobileaudio.com/forum...64-kickpanel-speaker-locations-pros-cons.html
Troubleshooting noise... What's next?
Midranges and Midbasses in Sub-Optimum Boxes
What are your best ways to bring up a soundstage?
Why are manufacture recommended enclosure volumes...
Sub facing question
Aiming a subwoofer
Aiming a subwoofer
Aiming a subwoofer
http://www.diymobileaudio.com/forum...ers/6125-another-fiberglass-box-tutorial.html
http://www.diymobileaudio.com/forum...on/129267-best-place-aim-pillar-tweeters.html
http://www.diymobileaudio.com/forum...cussion/65061-improve-your-soundstage-$2.html
http://www.diymobileaudio.com/forum...08-yaris-sedan-deadening-sound-system-10.html
http://www.diymobileaudio.com/forum...trim-panels-dashes-just-about-everything.html
IB (Infinite Baffle)
http://www.diymobileaudio.com/forum/technical-advanced-car-audio-discussion/154324-low-qts-eq-vs-high-qts-ib.html
IB Speaker Specs
http://www.diymobileaudio.com/forum...e-ib15-4ohm-car-version-idmax-comparison.html
anyone want to explan why im reading that a higher Fs is recomended for IB?
How do Fs, Xmax and Qtc affect Free Air Subs?
Qts and IB
What specific specs make an IB woofer, IB'able?
Free air IB subs
What's all this "Q" stuff?
Amplifiers
Can someone tell me/explain exactly what clipping is?
Do all competently designed and level matched amps/head units sound the same?
class a/b or d amp for subwoofer sq?
Is amplifier fusing a measure of true amp power?
Power and Wire
what is the real difference in pwr wire cca vs ofc vs copper weld
voltage x fuse amp = power output?
Speaker wire: the facts?
RELAYS; how they work and how to wire it up...
http://www.diymobileaudio.com/forum/general-car-audio-discussion/75127-best-rca-cables.html
http://www.diymobileaudio.com/forum/how-articles-provided-our-members/7517-science-cables.html
http://www.diymobileaudio.com/forum...08765-if-quality-rca-cables-so-important.html
The Ten Commandments of Noise Prevention
Various ways to use a basic relay
http://www.diymobileaudio.com/forum/car-audio-truth-myths-industry-dogma/134202-big-3-caps-general-electric-stuff.html
http://www.diymobileaudio.com/forum/general-car-audio-discussion/153384-capacitors-complete-waste-money.html
JBL FAQ
TECHFLEX 101 A Comprehensive Look At This Product
Wow, this is probably the most useful thread on the forum.
Thanks for posting!
1 - 10 of 10 Posts
