1 - 20 of 50 Posts
Ok I had had my PXA-H700 installed earlier this year for a few months but removed it along with the rest of the system and hadn't had it installed since.
Theres no question it's a versatile processor. Some people find some of the Para EQ features annoying, some have encountered noise issues, many say it's not Hi-Fi enough.
I won't comment on any of the features or what it can do since we all know what it can and can't do. Theres actually not much it can't do. It's more processor than most will ever need.
What I will be commenting on is the SOUND of the processor. Now I don't have access to countless pieces of mega buck gear but I have listened for considerable lengths of time to very high end, HIGH RESOLUTION systems. So I know whats possible with todays ubber expensive gear.
I can only comment on the differences it made on MY SYSTEM. While not top of the line it's a good choice of budget gear thats well over 10 years old with the exception of the Sony.
The system consists of:
Adcom ACE-15 line conditioner
Sony DVP-S7700 DVD/CD player for playback - Top of the line DVD from around 2000(MSRP$1200)thats very well reviewed with Copper case and considered a solid CD transport with very good digital filters. Many that reviewed it said it should have the ES designation. That would surely have added to the MSRP...so I guess they did us a favor.
Adcom GFA-545 II power amp
Adcom GFP-545 II preamp
Polk Audio Monitor 10 Series II - 2 6.5" woofers, soft dome tweeter and 10" passive radiator. Very well reviewed back in early 90's. Theres other spreakers I would have chose at the time but having a friend that worked at Tweeters I had access to many good deals. They've served me well for the past 17 years and a good match for my Adcom amp.
This test stems from many comments made that that the PXA-H700/701 is not sonically as transparent as other processors and not designed as well as it could have been. I had doubts I would want to use it in my system again. So I figured...I'm happy with the sound of my home gear. Why not compare it directly to the filters in my Sony source unit. Sony doesn't make the best of everything. But they've done seversl things very right in home audio and the DVP-S7700 DVD/CD player is a good example of this.
To keep things fair I went into the Adcom preamp from the H700. I hooked the RCAs from the Sony to Tape1 and the RCA's from the H700 to Tape2. That way A/B comparisons were only one click away. And of course I hooked th optical from the Sony into the Alpine.
I hooked up the Alpine to a 10 amp power supply which is sufficient for a low level device such as this.
I'll start by saying it introduced NO NOISE using the optical input.
After adjusting the X-Over and being sure all EQ settings were set to flat and no Mx processing was activated, all input/output adjustments were made and correct speakers were selected I was ready to go. I level matched on the Alpine unit to the listening level I chose from both inputs. I arrived at a 32 volume level.
I started out with some of the Zuki test discs and played some other well recorded CD's.
On the Opeth CD Ghost Reveries I was pleasantly surprised at the things I was hearing. Fingers sounds on guitar strings were very well defined and not just a backgroung sound. That guitar player was closer to me. Everything was just presented with more resolution. The bass guitar was more up front, bass drum attack and decay was more defined, vocals were more up front and cleaner, cymbals details came through. Everything was more clearly defined and not as confusing. I'm a drummer, so I know what cymbals sound like. Cymbals went from a ping to "OK I can tell thats a medium weight cymbal and not a heavy cymbal. There were overtones that weren't present before.
If any of you know the overhang you get with a nice sounding bass drum, well I heard this compared to a thud with the Sony filters. I felt on every recording I was closer to the recording studio. Like there was a piece of carpet removed from the front of the speakers.
As I write this I'm listening to Opeth/Ghost Reveries Requiem/Harlequins Forest and my spine is tingling from the level of resolution presented to me. I'm astounded. I'm also spoiled since without the Alpine processor the system doesn't move me as much. I feel as though I just hear the music and have no involvement. The Alpine brings you in there.
I felt like I was listening to a different system. My speakers are capable of performance I wasn't aware of. I now feel good saving these for a secondary system in the future.
On some not so stellar recordings there wasn't as much of a difference. But still things were clearer and sounded as if a veil was removed.
I haven't listened to nearly enough material as I'd like but I auditioned enough well recorded discs to have a solid opinion on the sonics of this processor.
In conclusion I'll say this. I do not doubt the sonics of this processor anymore. Despite the flaws it might have from a design standpoint, I am now reassured of one thing:
It sounds DAMN GOOD!:D
i would like to comment on the h701 and its rca interconnects.
having sound in the car without an optical cable for the input however, i do have induced noise. its not alt whine. its a scratchy high pitched buzz when the volume on the h701 is high and the volume on my 9830 is low. vice versa, it has a very very small but audible effect at high volumes.
im not sure how it is in other peoples installations - but i can not wait to upgrade to an optical output with DVDaudio support. and in the future HDDVDaudio :eek:
but thats my 2 cents.
Check this out:
http://www.elitecaraudio.com/forums/showthread.php?threadid=87972&pagenumber=1
This one needs a nudge to the top since it's such a popular unit and the best ALL- IN-ONE WONDER BOX.
Seen Rock City
I cannot disagree with that assesment.
For the price, there is no better DSP available today. Yeah... there are some quirks.
I am removing mine from the competition car and using the processing built into my amplifiers for next year. I am trying to minimize items in the signal path.
I know for sure that the following class champions from IASCA and MECA finals this year were running the 701:
Joe Karpus
Andy Jones
David Brooks
Solid piece for the dollars. That's fo sho!
Joe Karpus
Andy Jones
David Brooks
Brian how many people were using the Zapco Processing? I know Steve and Kirk are but not to sure after that.
This also reminds me that I really need to get to ATL and persuade Jeff to teach me how to properly use mine. I've jacked the GEQ up something horrible.
Other than that I have to agree as well with the review. I can't think of a better value I've ever invested in (car audio wise)
The Zapco DC Reference amps are the only solution I would consider to eliminate the H700.
I have to get my hands on a DC Reference just to do the A/B comparison.
I was blown away with the difference between the Sony D/A converters and the H700.
If the DC Reference processing is THAT much better I might cream my pants.:D
Moderator
If I sent you my DSP-6, you would want to get away from the computer while typing your review. It is not too far behind the Rane and my modded Bel Canto DAC2 in terms of sound...and both of those stomp the H900.
Well I might have been listening as I wrote the review but I did listen to over 6 hours worth of music over a 3 day period.
But I get what you're trying to say.
Sonically this processor might be very low on the totem pole compared to other processors.
But it still makes me grin on a daily basis listening to recordings I haven't heard in a while.
Is there any way to get inside the 701 and change out chips, etc, upgrade or is this completely undoable?
J/w if its possible not that i'd even try......wouldn't know where to begin.
Discussion Starter #14
Some guy in Indonesia had several mods performed on his H700.
Moderator
He's got about $240 worth of caps, $24 in opamps, and $200 in a new clock.
And it still hasn't addressed the major weakness in the 701- the volume control.
But if you guys want to throw $500 worth of parts at a $300 processor...go right a head.
I have been thinking of adding a clock upgrade to it with a synch wire to the 9861 that I'm currently running, since there seems to be some jitter issues going on there.
Sure it is a couple of hundred bucks more, but honestly the only thing I would consider upgrading to is the DEQX and that is a lot of hassle and more then a few bucks aswell...
Discussion Starter #17
Well if the cash isn't a problem I guess it's worth doing. But the badly designed volume control should be addressed.
Discussion Starter #18
Did some listening with Ai-Net into the PXA-H700 and things weren't so hot. More to follow......
1 - 20 of 50 Posts
