Id like it to be small footprint like the skar amp.
SK-M9005D
SK-M9005D
- Compact "Mini" Class D Full-Range Five Channel Car Amplifier
- The compact design of this amplifier series allows for maximum versatility
- RMS Power at 4 Ohms: 55W x 4 Channels + 300W x 1 Channel (14.4v)
- RMS Power at 2 Ohms: 85W x 4 Channels + 450W x 1 Channel (14.4v)
- RMS Power at 4 Ohms (Bridged): 170W x 2 Channels (14.4v)
- Frequency Response: 10Hz - 20kHz for CH 1-4 & 10Hz - 500Hz for CH 5
- Working Voltage: 8.5V - 16V
- Signal-to-Noise Ratio (Sensitivity): 85dB
- Damping Factor: 100<
- Low Level Input (Gain): 8V - 0.2V
- Speaker Output Adapter Connection: Yes
- Crossover Control: HPF / Full-Range / LPF
- 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC)
- LED Power & Protection Indicators
- Fuse Rating: 80 Amps
- 8 Gauge Power and Ground Input Terminals
- Remote Bass Knob and Cable Included
- Dimensions: 12.4" (Length) x 4.6" (Width) x 1.7" (Height)
- Channel 1/2 Crossover
- High-Pass Filter / Full-Range / Low-Pass Filter
- Variable Crossover Frequency Range: 20Hz - 500Hz
- Channel 3/4 Crossover
- Channel 5
- Low-Pass Filter Range: 50Hz - 500Hz
- Bass Boost: 0dB - 18dB
- Click Here to Download the SK-M Amplifier Manual
