1 - 13 of 13 Posts
.....that has adjustable x-over points for the fronts/rears (up to 4khz) and speaker level inputs
fronts and rears could be 50w + per ch. but the sub channel has to be at least 300w @ 4ohm
amp must be under $250...new or used :)
anyone has any recommendations?
thanks
If you can go a bit more I have a DLS A7 that may work for you
Beyond that, you may be better off with something like a refurb Kenwood X4r and some bridged 2 channel
thanks for your reply
I was looking into the 500/5 and perhaps staying with my Audiocontrol LC6
If you dont need variable crossover points for tweets and mids, the 500/5 is a nice amp.
Good power, and should be pretty close to what you need on sub channel, even though its rated a bit lower
I got a 500/5 cheap that needs to be repaired. PM me for info.
Discussion Starter · #7 ·
BTW the 500/5 will accept speaker-level inputs. Don't need a LOC, just need to wire some RCA ends to your speaker wire.
interesting
I will let you know if I decide do move up in price ;)
Discussion Starter · #8 ·
Discussion Starter · #12 ·
I looked into the HF...thanks :)
Zeus ZXi Series 5-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 55 watts x 4 chan. + 200 watts x 1 chan
2 ohms: 110 watts x 4 chan. + 300 watts x 1 chan
Bridged, 4 ohms: 220 watts x 2 chan. + 200 watts x 1 chan
Pulse width modulated (PWM) MOSFET power supply
LED power and protection indicators
Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
Variable input control
5/4/2 Channel operation
Soft turn-on circuitry
DC, short, thermal, and overload protection circuitry
Heavy duty aluminum alloy heatsink
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable high-pass filter (50-4000 Hz, 24 dB/octave)
Variable low-pass filter (250-4000 Hz, 24 dB/octave)
Channel 5 variable low-pass filter (30-150 Hz, 24 dB/octave)
Frequency response: 10-30000 Hz
Dimensions: 15.98"L x 9.45"W x 2.56"H
1 Year Warranty
Discussion Starter · #13 ·
I dont think it has speaker level inputs...but looks great for the price
1 - 13 of 13 Posts
