21 - 34 of 34 Posts
You mentioned in the other thread that you're thinking of taking the IB subs out and building a molded fiberglass box in the side of the trunk for a l5 kicker square 8” you have already. Perhaps your HU would then be sufficient to tame the overall system response well enough to call it good for the time being, or maybe even for good, so you can move on with your life and focus more of your time and resources on engine performance upgrades and such.
As I posted in the other thread,
In the wise words of fellow member, @dgage - "EVERY system has a bottleneck, it is just a matter of whether the bottleneck causes enough of a limit to be worth the expense to alleviate it (and move to another bottleneck)."
I’ll admit I haven’t read all posts. But response to original post:
Dayton dsp is good budget item, BUT only has 4 inputs, not 6. Why do you need 6? I use my front inputs to feed all of my mids/highs channels on dsp, and then use HU sub out to get to my sub. This way I can easily toggle sub on/off from HU.
If you don’t need to toggle sub but prefer front/rear fading capability, then use front/rear inputs for dsp.
Unless you really need 6 channels in, which would also force you at a higher price bracket, I’d suggest one of these compromises. I love my Dayton, though I’m sure better exists, for the money Dayton value is hard to beat. No issues with mine (some complain about noise, usually easy to resolve).
Someone mentioned being passive means dsp not required. I disagree. Even with a passive setup, the ability to TA, fine tune XO, and use parametric EQ per channel will still yield HUGE benefits over not having a dsp. But yes, for FULL benefit, an active setup is preferred.
Whatever dsp you get, highly suggest you budget for an RTA mic, often available $80-100. Minidsp umik-1 is popular.
Discussion Starter · #23 ·
See I'm not using the time alignment in my head unit and my sound stage is satisfactory for what I want. Theres still adjustments the radio has that helps that. It sounds like the sound is on top of my dash and its difficult to pinpoint where the bass is coming from. I adjusted the midbass levels to compliment the dash speakers just right.....however, the silverflutes need some crossing over because they dont sound good letting them sing at full range. The reason i wanted at least 6 inputs was to control front, rear and sub still through the headunit. My headunit does offer alot of adjustments that would compliment the dsp. I need the dsp on the subs to kill the "cabin gain" as some say that happens in my setup at 40hz.
If you’re dead set on having fader AND sub control from HU, then ya you’ll need 6-ch in, maybe the minidsp (608 I think) can work? Still pretty good value and price, even if it’s twice the price of Dayton.
I was in a similar boat re: wanting that control, but ultimately was happy to sacrifice the fader to save over 50% on the dsp. But everyone’s requirements are different.
But to be clear, you can still have all channels pass through the DSP even if you only have 2 inputs.
So it’s not like you lose the ability to dsp your subs or rear by going to 4-ch input, you just lose your ability to fade or toggle sub on/off from HU (you can still do that through your dsp though).
Good luck!
Discussion Starter · #26 · (Edited)
Good luck!
I just prefer all my controls be on the radio, that way i can turn it (the sub) off and on quickly, adjust the level quickly and change the crossover points...is just something I'm not willing to give up.
The Dayton has 3x2chan inputs, you can control the sub level from the Hu if you wish. If you want to lean about DSPs it a great option. I recently upgraded to a Helix and I honestly miss the interface
The Dayton only has 4 in and 8 out (hence the 408 model number). It’s 2 pairs of inputs, not 3.
Discussion Starter · #30 ·
what about the audiocontrol dqdx or the audiocontrol DM-608? The dqdx is pretty cheap, has 6 inputs and does not require a laptop to make changes...I kinda like the simplicity of it.
I thought man who go though turnstile sideways going to Bangkok
Yep, there are any sayings from the fellow.
I usually reserve your one for when we fly to Europe... Which seems to have been a long ago at this point.
Maybe we are related?
Entertainment Hat Performing arts Magenta Clown
Reactions: KFXGUY
21 - 34 of 34 Posts
