1 - 12 of 12 Posts
I have a bad channel on my KS 300.4. So I would like to replace it. I am looking for a 300.4 or even a 300.2 will work for my system..
I would prefer if the 300.4 was a V1 (which is a long shot) as that is what I have and the way I have them setup it would look the best. I think the 300.2 V1 is the same size
Might even consider a mono version as well if the sizing is close as I can swap stuff around..
What do you (hopefully) have
2011 Outback - Surf Pro 3 + Stock HU, HAT L1V2, HAT U3, DLS U6i, P6MKII, SFB-3000d, DD 9512
What are you running with you amp? I have a KS300.2 powering my DLS UP36i set at 4 ohm stereo. Plenty of power and never had any issues with it.
I was running a 3-way with a passive crossover.. I switched to active, pair of 6.5" and pair of tweeters and now the one channel does not work.
I Have another 300.4 bridged running a pair of woofers, so I could use that for the fronts and get a 300.2 for the rears.. Love the amps, just bummed the one has a bad channel now.. when it was bridged it seemed to work. net thought is swap the amps and see how that works
Got one in mint condition.. KS300.2 v2
might have my Amp fixed.. seems like a switch might be the problem..
Kenny I need to measure mine to confirm the length I have
That is a V1, mine measures the same.. Let me know what you would want for it.. I will know int he next few days if mine is fixed
Discussion Starter #12
No longer needed thanks to help on the forum all that was needed was Deoxit on the switches
1 - 12 of 12 Posts
