Discussion Starter · #2 ·
I talked to the guy at Madisound and he says that the Lotus Seas 4.5" driver doesn't come with grills or mounting hardware. Any idea on a good 4" midrange that comes with mounting hardware and grills. I want to replace my MB Quart DKD speakers and I want something high end. After all, I don't want to kick it
you can make your own grills..
http://seaslotus.com/specifications.asp
^power specs.
if youre planning to do an active 3-way, two 50x4 amps should be enough.
50 watts for the tweeters, 50 for the mids (4.5"), and ~200 watts for the midbasses (50x4 brided to ~200x2).
DIYMA Founder
~35w continuous power is plenty for the set, and for the midrange maybe ~15w. Depending on your gain structure you may need a bigger amp to get that kind of power output.
