1 - 20 of 31 Posts
Just wondering if the LPGs would sound bad crossed at 2500hz?
Just to be helpful to the OP, what x-over slope is going unspoken here?
Those tweets are meant to be a part of 3-way set-up, and they will sound strained even at 5khz/24db.
I want to use these tweets to replace the seas rt25f from the original seas lotus refs. One of the tweeters went out on me. I'm running them passive with the seas crossovers.
definitely want to look elsewhere for 2500hz. I'm pretty sure i posted a tutorial on adding a felt pad on the polepiece of the lpg's which greatly improves it's performance below 5-6khz.
I looked at those and looked at those and NEVER found ANYTHING from LPG/Eaton that recommended them be used in a 3-way.........
Why not use another pair of the Seas tweets? If it's a Seas passive set, then the x-over will be configured for that particular tweet and chances are very good that inserting the LPG's will not work properly.
Discussion Starter · #10 ·
I wanted to use the seas aluminum tweeter but madisound is out of stock.
LPG's are 8ohm and that can present another set of problems.
I've run mine down to 3500hz on 24db/oct, but lower than that got ugly. Also depends on how hard you want to drive them.
Do Seas give the xover frequencies and slopes for their passive set? First time I've seen a manufacturer that open... Bravo to Seas if that's the case.
i have the seas rt25f and the factory crossover is 1700 hz for the passive xovers. i run them activly at about 2250hz, but the rt25f has a pretty low fs, i doubt they would work very good with the factory seas reference crossovers, if the lpg is more ment for the highs. the seas tweeter is actually one of the lowest dome tweeter i have seen.
If you look at the specs and actually have personal experience with the set, you'd know what I mean. They sound like total crap under 5k even with 24db slope, that is what I meant, if you want to be picky. Even Seas Neo sounds strained lower than 3.5k/24 db, so if he wants to go low to 2.5k, then he may have to use something with FS of 900hz or lower. This is how I would do it, some people may possibly like the strained sound - not me.
Discussion Starter · #15 ·
So what are my options on another tweeter to use passive with this set? Worst timing possible for this tweeter to go out on me.
I'll tell you like I've told a dozen other people. Passive crossovers are designed for the drivers that are packaged together. Throwing a random tweeter into those passives isn't going to be good no matter how "nice" the tweeter is. Either find a direct replacement, or consider either going active or picking up a whole new component set.
I have and I have, I also currently own the seas Neo which is not in use.
I don't understand why you think you can't mate them with an appropriate 6-7" driver.
Discussion Starter · #18 ·
I'm trying to keep my costs down at this time though.
www.meniscusaudio.com... much better than Madisound... they actually package their **** properly, ship your items on time, and respond to your emails :rolleyes:
...and I cant understand why you cant contribute to the thread in a positive way, you need a girlfriend, way too miserable. I am off this thread as I do not wish to argue.
Life must be hard for you :(
1 - 20 of 31 Posts
