1 - 6 of 6 Posts
Since I can't get any T/S's, how would this driver perform in the above mentioned enclosure, sealed of course?
Re: 3.9 Ohms
Le: 0.76 mH
Fs: 29 Hz
Vas: 75 liters
Sd: 490 cm^2
BL: 14.0
Qms: 4.0
Qes: .494
Qts: .44
SPL: 87.6
Mms: 135 g
Xmax: 16mm
Xsus: 22mm
I'm baaaack!!
I would not recommend a .75 ft^3 sealed for the Mag AT ALL! In the testing I did, I found the Mag best suited in sealed boxes ranging from 1 - 1.25 ft^3.
If he says so -I also concur that I have the Mag in 1.3 cubes sealed -before sub displacement...
Maybe try a "leaky box"?
Enclosure calculators are probably going to come up with larger sealed enclosures than 1 ft^3, but the Mag v4 was specifically designed for 1.0 ft^3 sealed only. You can shoot for a .707 alignment, but the juice isn't worth the squeeze compared to the optimized 1.0 enclosure size. With a larger enclosure the F3 isn't that much lower, the box size is significantly larger, and the power handling goes down significantly.
1 - 6 of 6 Posts
