1 - 11 of 11 Posts
So last week for my birthday my wife bought me a "system" for my boat. I have a 24' Grady White and had spent the last month planning out how and what I wanted to do with it. I really couldnt decide because I really didnt care that much about tunes on the boat since I really am more of a fisherman than an audiophile on the boat. A bit worried about much electronics I dont need when heading out 50-100 miles offshore.
Anyway she bought me a "Boss" system that is simply a head unit and 4 - 6.5" coax. It has bluetooth and a remote. I think I may build some simple PVC cap pods for them. I have some leftover gear from a car I did last which is a Pioneer 4 channel 8604 and a mono 9601. Also have the SI MKII shallow sub and box but I dont think I want to use that on the boat. May just buy a cheapy or a marine sub and box. I have a cabin and can keep stuff dry easily.
My first question is there are 2 RCA out (L and R I believe) on the head unit along with 4 speaker outs. Do I want to run the 4 speaker outs to the 4 channel amp and then the 2 RCA outs to the mono for the sub?
Could justify doing either way, depends on the headunit controls/options.
If the rca's make more sense to use just for sub control(read the HU manual), that might make more sense.
Yeah the manual doesnt really tell you much on this one. Im just hoping by adding a sub I can make this sound decent.
Im trying to figure out where I want to put the amps too. Its a long run from the batterys to the cabin. I guess I could put the amps back by the batteries because its pretty dry back there too. It would be a longer run for the speaker wires, but they would be much cheaper than 50' of power wire and 50' of ground wire.
Ha! I say pretty dry because it is, after all, a boat. So the potential is always there to get wet. This is equiptment that I already had, and I dont think I paid much for it to start with. So if it gets jacked...so be it.
Since I really dont want to ruin my SI MKII, what would you recommend for a boat? I assume you wont really get accurate bass in a boat because its open air and really fairly noisy. Im just wanting a single. Would a 12" be better than a 10" in this application? Normally like 10" for my autos, but this is totally different. I was thinking maybe a $100 sub in a ported box. Maybe I should check craigslist for something decent and cheap.
Yeah, would look for used in that case. Doesn't have to be fancy.
Well crap. Another monkey wrench! I just looked at the amps. There is no provison for speaker wire inputs. RCA only. I did see that the amps have an output. Can I run the RCA out from the HU into one of the amps, then from that amp output to the other amp input?
Yep, that'll do it.
Cool good luck, if you have any doubts check the amp's manuals quick. Should work well.
Thanks! I believe I threw the boxes (which I hope have the manuals) in the attic. Now where did I put the bass boost knob??!!
1 - 11 of 11 Posts
