I just came across this amp and had to pick it up. From the research I've done, it appears to have been made in Italy back around 2005 by "Renegade". I've found a full color brochure of the 2005 line including this amp (but it's in German), but I'd REALLY like an owner's manual on this one. Anyone? Here are the specs I've found using Google (and google translate):
The Dragster brand from Italy is known for very good sounding amps. Excellent workmanship combined with a stylish design are just a figurehead of this high-end manufacturer, this power comes in all walks of life up to the top model DH 1804, with impressive values.
PWM MOSFET power supplies
Variable Crossovers
RedRubin aluminum heat sink
High-quality epoxy circuit boards
2 ohm stable stereo
Sealed potentiometers
Teflon-plated RCA connectors
High Speed HEXFET audio outputs
4 x 180 / 300 watts RMS at 4 / 2 Ohms
2 x 600 watts RMS into 4 ohms
variable 50-500Hz HP / LP filter for Front & Rear
Distortion 0.05% Signal-to> 103 dB
Dimensions: 740 x 55 x 245 mm
The amp is 33" long and makes the Orion XTR2250 "Beast" look not so beastly
Variable Crossovers
2 ohm stable stereo
