1 - 2 of 2 Posts
overstock of NX5 amps..
PM for pricing
FREE BASS Remote with each amp, (on in stock remotes) And SPECIAL PRICING ON NEW CK6 V comps.. with order
Massive Audio NX5 Nano Block Series 5-Channel Car Amplifier
RMS Power Rating:
4 ohms: 120 watts x 4 chan. + 200 watts x 1 chan.
2 ohms: 240 watts x 4 chan. + 400 watts x 1 chan.
1 ohm: 800 watts x 1 chan. (Subwoofer channel only)
Bridged, 4 ohms: 480 watts x 2 chan. + 200 watts x 1 chan.
MOSFET power supply with high grade switching devices
LED power/protect indicators
Designed to fit into restrictive or limited spaces while still delivering staggering amounts of power
Ultra efficient Nano Technology power supplies
2-Channel operation
Extreme power in a small footprint
Ultimate mounting flexibility (stackable, line array, side mount)
Mill Spec double sided PCB with SMD parts
Built-In noise reduction circuitry
Heavy duty aluminum alloy heatsink anodized in a Raven Black finish for extreme heat dissipation
3-Way protection circuitry (short circuit, overheating and Low Voltage)
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Adjustable high-pass filter (40-200 Hz, 24 dB/octave)
Adjustable low-pass filter (20-200 Hz, 24 dB/octave)
Frequency response: 20-25,000 Hz
THD (Total Harmonic Distortion): <0.05%
Signal-to-Noise Ratio: >89 dB
Max Voltage: 15V
Max RCA Voltage: 5V
4-gauge power and ground wiring is required for installation.
CEA-2006 compliant amplifier
Dimensions: 15"L x 5-1/2"W x 2-1/8"H
1 - 2 of 2 Posts
