1 - 3 of 3 Posts
· Registered
With a 3 way active system. If using amps that have active crossovers built in instead of an active capable deck, how would you be able to connect everything. You would have 4 RCA pairs to connect. One for sub, midbass, midrange, and tweeters. From what I have seen most decks only have front rear and sub outputs. How do you get around this problem.
Here are the specifics
Soundstream Rubicon amps. I'm not sure of the deck yet, gonna hold out and see what shows up in classifieds.
RUB 1.1600
RUB 2.600
RUB 4.600
CDT TW-25 (silk)
CDT ES-3
ID OEMs if i can get my hands on them
IDMAX 12" D2
· Registered
If you are using the active crossovers inside the amps you should be able to use the AUX output of each amp to daisy chain them. I would have to check hte SoundStream specs but the outputs should just be a pass through from the input.
· Registered
i dont think that there are any aux outputs. I will have to double check. If there are not could I use a line driver to make more outputs?
1 - 3 of 3 Posts
