Application: Pair of Dynaudio MW160s. Future application: Pair of Dynaudio MW180's.
I understand that there are many factors that determine the quality of an amplifier, not just wattage. This is why I ask this question.
JL 300/2
Rated Power (stereo): 150 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm
S/N Ratio*: >108.5 dB below rated power
Damping Factor:>200 @ 4 ohm per ch./50 Hz
40A Fuse (1 or 2?)
MB Quart RAA2400
200 watts RMS x 2 at 4 ohms (400 watts x 2 at 2 ohms)
<1%THD
Signal-to-Noise (S/N 1 Watt @ 4-Ohms) - >95 dBA (1 Watt @ 4-Ohms)
No Damping factor available
fuse rating: 30A x 3
I know questions like this are frowned upon, but i would like some technical information on what makes 1 better than the other. Especially if you believe the JL to be superior considering it is rated at 50 watts less than the Quart.
Another thing, that 50 watts, does it make a noticeable difference?
Thank you.
JL 300/2
40A Fuse (1 or 2?)
MB Quart RAA2400
<1%THD
Thank you.
