1 - 17 of 17 Posts
McIntosh MSS650 and McIntosh MSS530 and McIntosh MS480 Tweeters
NEW
4 available - McIntosh MSS650 - $600 ea. shipped
14 available - McIntosh MSS530 - $400 ea. shipped
28 available - McIntosh MS480 Tweeters - $30 ea. (sold individually) $60 per set shipped
Included
90% of the speaker sets are in sealed cartons, I have opened a set of each for pictures. The tweeters were on a tray so they will come wrapped in bubble wrap in a USPS small flat rate box.
McIntosh MS480s are 2 5/16" mounting diameter, Front trim is 2 5/8" OD Mounting depth is 7/8"
They are marked as 150W Max Power, 4 Ohms
I have an email over to Roger Russell for info on these tweeters. I will update if I have more information. If anyone else does that would also be nice.
How old are these? Very cool either way.
I'd have to look, most are sealed and I don't recall a date on them. I'll do some digging and see what I can find.
Thx
Just an FYI, if someone wants 2 sets of the 530s I would do $700 shipped to help. Thx
No interest huh?
Discussion Starter · #7 ·
It would help if you dig out their parameters.
I would say that is a very fair and valid point, thank you sir.
For the MS650:
Specs are as follows:
Driver- MS650
Tweeter- MS10
Crossover- MN650
120 W RMS
60 W Continuous
Frequency Response - 80hz - 8k hz
Impedence- 4Ohms
Free Air Resonance - 47 Hz
Total Q- .46
Voice Coil Resistance - 3.3Ohms
Piston Area 0.0127 sq m
Flux Density x wire length BL 4.7 TM
Zmax 37 Ohms
Reference Efficiency .5%
Mechanical Q 5.2
Electrical Q .5
Mechanical Compliance Cms 1026 uM/N
Moving Mass + Air Load 11 grams
Voice Coil winding height 9.5mm
MS530:
General Features:
5-1/4" Component Speaker System
Die-Cast Aluminum Baskets
Tinsel Voice Coil Leads
Neodymium Magnet Structures
High Temperature ABS Enclosure
Minimal Mounting Dimensions
Peak Power
120 Watts
Continuous Power (EIA + H.P.)
60 Watts
Frequency Response
80 Hz - 20kHz
System Sensitivity
85 dB
Nominal Impedance (Znom)
4 Ohms
Crossover Frequency
2400 Hz
Low Pass Slope
12 db/oct
High Pass Slope
12 db/oct
MS530 Woofer/Midrange Mounting Dimensions
Grille Overall (Diameter)
6-9/16” (166.7mm)
Speaker + Grille Overall Depth
3-7/16” (87.3mm)
Speaker Mounting Depth
2-3/4”(70mm)
Mounting Hole Diameter
4-3/4”(121mm)
MS20 Tweeter Mounting Dimensions
Housing Overall (Diameter)
2-1/8” (54mm)
7/8” (22.2mm)
9/16”(14.2mm)
1-3/4”(44.5mm)
MN530 Crossover Mounting Dimensions
WIdth
2.7” (6.86mm)
Height
5.2” (13.20mm)
Depth
1.4”(3.4mm)
Tweeters: MS480
I can take measurements of these with Dayton WOOFER TESTER.
let me know, id be glad to do so. Let me know what you are looking for in regards to this.
Discussion Starter · #8 ·
UPup
Discussion Starter · #9 ·
Special price $360 ea. For the MS530s 5.25" component's
Discussion Starter · #10 ·
Bump for xmas
Discussion Starter · #11 ·
CHRISTMAS COMPONENT SALE - GET THEM WHILE THEY ARE HERE
BEST PRICE - GUARANTEED
Discussion Starter · #12 ·
XMAS bump - only 5.25" left
Any more specs on the tweeters? Does anybody have any experience with a pair of them?
Discussion Starter · #14 ·
I don't sorry,
Let me say this. Out of the 10 or so sets that have sold no bad feedback?
Discussion Starter · #16 ·
Yes, sorry sold 10 sets of the tweeters. I have sold most of the MSS650 but not many of the 5.25". must be a uncommon size?
thx
1 - 17 of 17 Posts
