1 - 6 of 6 Posts
can I measure volts and ohms at frequencies and figure out how much power I'm sending my speakers?
well I measured my subs ohms at 50hz and power source's Volts at 50hz. I got 8.7 ohms and 20volts. which is around 45watts following the formula
V^2/ohms = watts
I also measured my mids at 1000hz and got 2.6ohms and 3.35 Volts for power. which is 4.3 watts.
is this accurate?
I think the test tone needs to be a sine wave at the certain frequency in order to get the correct voltage. I know you can set your gains using sine waves and known wattages to find your input/ouput voltages.
yea the voltage I got was stable with the sine wave I used. I tested a few waves....all came at around the same voltage.
I'm not sure if the ohms I read from the speaker is accurate. I think it is.
DIYMA Founder
I usually measure current through the speaker, then voltage and multiply the two to get power. But what you're doing is accurate. Much less power being used than you thought?
Discussion Starter · #5 · (Edited)
yeap yeap.... :) ......thats a good thing. 5 watts to the speakers and I'm good.
even 8ohm speakers judging from the effiency at 2.8V will do good with a few Volts of power.
btw....do you ever just use your HU with comps and such?.
btw...again...remember when I gave my opinion on my MB quart comps....well I recently found out one of my mids was messed up. So the review was off a bit, well that is if I was using the messed up mid...I was only using one....not sure which though.
it's amazing what u can do with so little power. people think they need 200 watts on their midbass. why i dont know. my CA18's are getting just under 17 watts and they get quite loud on that little amount of power. with gains all the way down too i might add.
1 - 6 of 6 Posts
