1 - 20 of 42 Posts
i had this hooked to my front speakers and hooked a set of off brands up to the same ch, drove around to test them and when i was pulling back in the sound went off. checked the amp and it was going from power to protect and kept doing it. unhooked all speakers and still does it, im guessing i ran the ohm load wrong? what would this have messed up? took apart and nothing looks blown or visible...
did you check the fuses inside it i havent even heard of this model so im not sure but it could be a faulty output stage or even power supply or straight up fuse if this is the pic of the amp and you bought it neww however then there goes your warrenty
quickest way to loose warrenty on an amp take the back off it
Ren
xMplar
1 - 20 of 42 Posts
