1 - 9 of 9 Posts
· Registered
there seems to be differing output between my two midranges. they both are playing clean,but one is playing more detailed and higher. i have switched amp channels and had a listen with them out of the enclosures,same result.
[email protected] [email protected]
is my driver on its way out?
thanks
could be a phase issue = check and double check your + and - at the amp and the speaker , then check your ohm level on the speaker terminals , if nothing yet swap patch cords --- is this a component set with tweeter ??
· Registered
Discussion Starter · #7 ·
they are in kicks, but i did pull the drivers to see if it was the enclosure.the problem was still there. even listening out of the enclosures the highs just seem to be lacking in the one driver.
1 - 9 of 9 Posts
