@oabeieo regarding setting the crossovers before/after running Dirac
This is a simulation of my crossover points per speaker, assuming a flat house target and 24 slope LR filters.
Tweeters HPF 2500hz LR24
Mids BPF 250 to 2500 LR24
Woofers BPF 80 to 250 LR24
Front Sub BPF 60 to 80 LR24
Back Sub LPF 60 LR24
Let's assume that I've calibrated Dirac having each speaker playing full range (when possible).
In theory, After running Dirac I should be able to set the previous crossover points and get a flat line right? LR24 phase sums up perfectly so...
Let's see what happens:
Ok, that's not what we were expecting right? ..but why?
Because the phase from the front sub is being affected by both LPF and HPF. To get it perfectly blending, I'll need to compensate for it with time, and ensure that I either have phase slopes aligned or maximum phase at the crossover point.
Ok this looks much better! So to have a perfect blend, I actually need to delay my back sub by around 6ms!
Let's add woofers now and see what happens. I'm going to create a copy of this sum and use it as a reference from this point onwards.
Hum.. not flat..but not bad I guess? Can it get better?
That looks a bit better. So i'll need to increase 1ms to both subs to get a good blending between the three groups of speakers.. now i'll add another copy of the cumulative FR and add the midrange to that:
Out of phase?!
You see where i'm going right? adding the crossovers is not as simple as we whish for..
To be honest, since Dirac is applying phase (and timing) corrections, the only way to actually set it right is with rew.. or using one dirac channel for Left, another for Right and another one for sub(s). This way Dirac will ensure that the FR is corrected for the crossover points as well. Sub channel will always have to be aligned manually.
