281 - 290 of 290 Posts
I figured out what I was doing that was causing DL to produce bizarre delays. This was how my process went when adjusting to target:
  1. Load/adjust target for fronts
  2. Click "Optimize"
  3. Load/adjust target for sub
  4. Click "Optimize"
My guess is that it was optimizing for incomplete adjustment and simply f'ed it up. When I optimize with this process, I get great results
  2. Load/adjust target for sub
  3. Click "Optimize"
Guys, just installed my new c-dsp 8x12 and upgraded it to DL.
Getting used to C-DSP software.
I connected fiio M11 via spdif to C-DSP, but not getting any signal on channels 7 and 8 (digital).
Everything works when using one low level input.
The cable is neotech NEI-5001. 3.5-RCA.
What can be the problem? Thank you!
Just to clarify, if you do go with MiniDSP Dirac, UMIK-1 will be required. Dirac only works with UMIK-1. So, UMIK-1 is a better choice from that standpoint.
Not sure if its dependent on the Dirac Live version 1.0 vs 2.0.
But on Dirac Live 2.0 on the DDRC-22, I am able to select and use my OmniMic v2 with its own calibration file.
A bit off topic but is it possible to get the house curve you guys are using. I think the wisdom curve that’s in the minidsp. It looks intriguing or can someone replicate it to input the data in jazzi spread sheet.
Talk about timing.... I literally just did this today to experiment with it. I flattened out the slight roll-offs below 40hz and above 10khz.
Enjoy!
20 4
25 4
31 4
40 4
50 4
63 3.7
80 3.6
100 3
125 2.5
160 1.9
200 1.4
250 1
315 0.8
400 0.6
500 0.5
630 0.4
800 0.2
1000 0
1200 -0.2
1600 -0.6
2000 -0.8
2500 -1
3100 -1.3
4000 -1.5
5000 -1.6
6300 -1.8
8000 -1.9
10000 -2
12000 -2.1
16000 -2.1
20000 -2.1
And... I attached the text file but then thought maybe some could not see it so I edited the post with the values :)
oh sorry, I was wondering what happened with your experiment and how did it sound?
Still in progress....
Though, at least 2 other people I know have tried it and liked it.
I believe the auto targets DLCT suggest on the filter design screen are based on this.... but that should be confirmed by someone else too.
