First impression is that they look much better in person than in the pictures I have seen online... On Mmats site they have a smooth grey-ish look to them, but they are actually a textured black.
The covers can be flipped with the four allen bolts, so the logos face the same direction if you need to reverse them.
These are the Hifi6150 and the M2000.2:
I have had multiple emails with the president of the company, David Thompson, and he has been very quick to respond and extremely helpful. He even had the SoCal Director of Sales contact me to offer his help if I were to need it and to makes sure that "I had a good experience ordering through my local dealer..."
So far I am very impressed with the company and I can't wait to get these amps installed!!!
Nice. Can you take a close up of the speaker connector of the 6150? That’s the only criticism I can come up with, everything else looks great on those amps.
Sure thing, here ya go... That is probably my least favorite feature, but I guess it's kind of nice to be able to unplug speaker wires really quick without mixing them up.
Btw, I did just pull one out and they are super tight. I'd say it will take a 14 gauge wire comfortably.
I actually like phoenix connectors like that over set screws for speakers. Especially with the prevalence of CCA wire its less likely to break in terminals like that without having to use ferrules.
Agree with the OP. My exterience with MMATS has been top notch.
Right from pre-purchase when I was asking them a lot of questions, to their hassle free delivery to Canada.
The amps are solid. I've had mine for a couple years now. No issues (other than I just replaced the fans in both of them).
When the amps are new, the fans are dead silent. But after about 6 months, they start to get noisey.
I like how they don't fuck around... and just use a power block as the speaker output on their mono sub amps!
Effectively, you could whack a 4awg pair of cables in there, and use them for speaker wire!
4awg speaker wire...
The speaker blocks can take up to 12awg (tested and verified). I've never had one pull out. They're in there tight.
Good to know, thanks! The Mmats website does claim it will fit up to a 12 gauge, too...
I'm using 14 gauge on my speakers now, but 12 on my subs (which obviously won't be an issue with the M2000.2
On a different note
IMHO, the Hifi6150 is a nearly perfect one amp solution for a 2way and sub with great ouput! 4 x 150 Watts RMS @ 4 ohms + 1000 Watts RMS @ 1 ohm mono
And it's small enough to fit in most installs.
I'm assuming this question was for me. I have an Arc 1200.6, the amp has 3 on-board 30 amp fuses.......I don't see any on-board fuses on Matts amps so that's what I was asking about.
I also have mini anl fuses at the +ve battery post connection and also at my distro block but this wasn't what i was inquiring about, was about the onboard fuses on the amp itself.
Well, it was actually meant for JimmyDee as he already has these amps... I'm trying figure out what style fuses I am gonna use. They might be visible on my amp rack, so they need to look pretty good.
You could use a fused distribution block like the KnuKonceptz Bassik 3-way. You can also just go without one. It isn't necessary. The amp has a protection mode that will cut it off if it surges. The fuse is for the wire, which you already have at your battery. So as long as the run of your wire from distro block to amp can handle the amperage of the fuse at the battery you are fine.
For example, you fused at your battery 200A for a 20' run of 1/0 but you use 4ga from block to amp. While 4ga couldn't handle 200a on a 20' run, it could handle it on a 3' run. So another fuse on the 4ga line is not necessary in this case. But if you have a 300A fuse at the battery, then you'd want a lower amp fuse on the 3' run of 4ga.
I used those in my distro for years and prefer them to be honest. Still use one under the hood. Only using AGU fuses now because I needed a new block to replace my 10 y/o MAXI one and the one given to me takes AGU fuses.
Hopefully this isn't retarded:
I want independent volume control for the Master (total system), rear fill, subwoofer, and front stage and sub. I bought my own pots, cable, RCA connectors, PCB's and everything else I need to make a bunch of RCA level controllers (3 total for current iteration)...
Alpine MRV F407- running Tweeters off channels 1/2 high passed, and the woofers off channel 3/4 band-passed...
I have thought for a awhile now that my two tweeters were out of whack sound level wise- it is very subtle, and I thought maybe my right ear has some hearing degradation compare to the...
This morning, I was reading a few old posts (like 5 year old posts), and noticed a handful of names, that I haven't seen on this site for some time.
Just wondering whatever happened to these guys:
QualitySound
https://www.diymobileaudio.com/forum/members/qualitysound.html
BuickGN...
Got a couple questions.
Wife wants Apple Car play for her car. No other real changes to system.
Don't need any disc media. I was looking at
Kenwood DMX9706S - https://www.sonicelectronix.com/item_177351_Kenwood-DMX9706S-Car-Stereo-Free-NVX-Wireless-Charger.html
Open to other suggestions...
