1 - 12 of 12 Posts
Buyer pays shipping.
For the pair of MMats amps i am asking $450 (plus shipping). ($250 for the D300HC and $225 for the LM4065) The LM406 is a 2ch bridged BEAST! U loose no SQ with this amp.
If you know MMats u know how crazy small the d300hc is and how much pwr it puts out.
Black MMats D300HC
RMS Power at 13.8V
1400W into 2 ohms with less than 1% THD+N
S/N Ratio: -92db A-Wtd
Frequency Response: <10 to 225Hz
Lowpass Filter: Variable 24db, 70 to 200Hz
Idle Current: 1A
Dimensions (LxWxH): 12” x 9.25” x 2.25”
Black MMats LM4065
4x65W @ 4ohm
4x130W @ 2ohm
2x260W @ 4ohm bridged
Frequency Response (3db) 10 Hz to 25 KHz
Signal to Noise Ratio -105db A weighted
Distortion @ Rated Output <0.05% THD+N
Damping Factor @ 100 Hz >125
Input Sensitivity 150mV to 2.5Vrms
Idle Current 1 amp
JL Audio 300/4 Asking $225 plus ship
4x75 @ 1.5 - 4 Ohm
2x150 @ 1.5 - 4 Ohm
THD at Rated Power: <0.03% @ 4 ohm per ch.
S/N Ratio: >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 Hz - 30 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz
>100 @ 2 ohm per ch. / 50 Hz
Slew Rate: ±25 V / µS @ 4 ohm per ch.
Left to Right Channel Separation: >75 dB @ 1 kHz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.36 in.
340 mm x 235 mm x 60 mm
(2) JL Audio 500/1
asking $250 (each) plus ship
Rated Power: 500 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power: <0.05% @ 4 ohm
S/N Ratio: >95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 Hz - 250 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm / 50 Hz
>250 @ 2 ohm / 50 Hz
Will sell the 300/4 and 1 500/1 for $450 plus ship.
Image Dynamics Q600.1 asking $250 plus ship
POWER @ 14.4V <1% THD + N
RMS AT 4 Ohm , STEREO = 250 x 1
RMS AT 2 Ohm , STEREO = 400 x 1
RMS AT 1 Ohm , STEREO = 600W X 1
S/N RATIO @ rated power > 98dB
INPUT SENSITIVITY = 0.15V ~ 6.0V
INPUT IMPEDENCE = 20 KOhm
DAMPING FACTOR @ 50 Hz = > 100 @ 2 ohms
FUSE RATING = 40A x2
WIDTH = 8.5 / 222mm
HEIGHT = 2.125 / 54mm
LENGTH 13.75 / 349mm
AND
Image Dynamics Q450.4 asking $250 plus ship
RMS AT 4 Ohm , STEREO = 75 x4
RMS AT 2 Ohm , STEREO = 125 x 4
RMS AT 4 Ohm , STEREO BRIDGED = 250 x 2
S/N RATIO @ rated power > 100dB
THD+N typical/rated power = 0.05% / <1%
CHANNEL SEPARATION = >65dB
INPUT SENSITIVITY = 0.15V ~ 5.0mV
WIDTH = 8.5 / 222mm
Will sell both ID amps for $450 plus ship
Pics will be avail Saturday afternoon.
I can vouch for the D300HC. Those are brutal amps! Nice price as well, normally they sell for 300+ ship.
I got tied up doing other little projects this weekend. Pics will be avail Monday evening.
Black MMats D300HC
RMS Power at 13.8V
Idle Current: 1A
Black MMats LM4065
4x65W @ 4ohm
4x130W @ 2ohm
Idle Current 1 amp
4x75 @ 1.5 - 4 Ohm
2x150 @ 1.5 - 4 Ohm
(2) JL Audio 500/1 asking $250 (each) plus ship
250 @ 2 ohm / 50 Hz
WIDTH = 8.5 / 222mm
AND
WIDTH = 8.5 / 222mm
Do you still have mmats left buddy?
1 - 12 of 12 Posts
