Hi All
Its been a while since ive done anything car audio. This seemed like the best section for this post.
Short version:
Which affordable Class D amps are the best/arnt rubbish?
Ive been browsing at the various options and its difficult to know what to go for. I figured class D would be better for overly sensitive car electrical systems these days. plus i want to locate the amp(s) behind the boot side panel, so small and cool is also good.
I'm based in the UK, so not all brands that are available in the US can be had here for sensible money, if at all.
Shortish version:
Ive been looking at the specs, specifically the CEA signal to noise ratio (1w into 4ohm) of a bunch of different amps. In theory at least, the signal to noise ratio is a good indicator of the quality of an amp and the CEA spec should keep all things equal. I'm trying to avoid getting hiss through the tweeters. I doubt i can tell the difference between a THD of 0.05% or 0.01% or between 60W or 80W, but i will hear hiss. Particularly because the output of my MiniDSP is about 1v RMS max, so i'd have the input of the amp up quite high. In theory, this shouldnt cause an issue as the DSP will be close to the amp, and its not really a "Gain" control anyway, so noise shouldnt really increase with the sensitivity control significantly, though thats not to say it definitely wont.
Usually you have to look in the manuals for the CEA S/N but ive seen values from 75 up to about 88dB with a few in the 90s that were AB amps i think.
What sort of CEA S/N is considered good?
I cant really justify a big outlay, especially since warranty periods aren't often more that a year, also, i dont really know how much space i have to play with, but im trying to get the lay of the land on amps.
I'm thinking of a 4 channel amp for the fronts and then maybe another, hairier, 4 channel for the under seats and the sub. JL Audio seem like a safe bet, but they are pretty expensive, and most of the ranges seem largely the same, which is odd. i see Pioneer make something suitable, though i have heard comments about hiss. Rockford fosgate, and some of the other USA brands from back in the day also how some amps at various prices, but are they any good these days?
Longer version:
I'm in the planning stages of a new system, in a brand new car that isnt even built yet. Its a BMW 128ti (the closest in the US looks to be the 228 Gran Coupe) and due to the semiconductor shortages, i wasnt able to order the HK audio upgrade. Its not great anyway, but it would have been better than the standard system. Anyway, ive decided to look into putting a new system in. The car should have:
4" in the doors
4" in the rear doors
6 or 8" under the seats
the standard audio doesnt have the tweeters by the mirrors, the centre speaker in the dash, or the rear speakers in the roof that the HK system has.
My plan is currently:
Fit tweeters into the existing trims by the mirrors, run separate cables to these to run them active.
Fit some nicer 4" drivers into the doors.
Upgrade the speakers under the seats. There are a number of companies that make custom fit speakers that fit here.
Maybe run a slimline sub in the space under the boot floor.
leave the rears alone, and fade it to the front.
The "Receiver Audio module" is in the boot and seems to have 6 separate audio outputs. 2 for the front doors, 2 for the rear doors and 2 for the underseat woofers.
i have a Wavtech Link 4 that would take the fronts, and the underseat speaker outputs and sum them together into a single pair. this will then feed to 2x MiniDSP 2x4s that i already have one for left and one for right. I'll use the parametric EQs on the inputs to flatten the output from the car, then set the outputs for tweeter, mid, midbass, subwoofer (maybe) and tune from there. The advantage of doing it this way, is that i should be able to run a separate output from say a DAC from my phone into the other DSP input as an alternative source that is potentially better than what is coming out of the car. So i just need the amps to be amps. i dont need high level inputs on onboard DSP.
If youve got this far, thanks for sticking with me.
Cheers
Short version:
Shortish version:
Longer version:
4" in the doors
Cheers
