1 - 20 of 34 Posts
2004 Rav4 JL900/5 NVXvad2 MiniDsp 8x12(Dirac) LPG26NA GS25 Epique180-44 (2)Um12
Like stated, I have to focus my attention on something other than my noise issue and I want to talk about the possibility of any big boy 8 channel amps. I saw the unicorn old Phoenix gold 9 channel and it got me thinking. The only thing I’ve found even close to what I’m asking about is this marine brand
Even if it’s a $5k amp, I’d still like to know what might be out there. Just humor me as I don’t want to bring any talk about my noise, just a possible one amp solution
Discussion Starter · #2 ·
I would also happy talk about building a crossover for my gs25’s and Lpg26na sails.
Discussion Starter · #7 ·
Biketronics could make you a custom 8 channel. Two of their BT4250 boards in one chassis would be cool and only 7" x 11" or so.
I’ve thought about biketronic amps they do custom huh, wouldn’t be terrible to have a 150x4 and a 250x4.
2006 Hyundai Sonata V6
I forgot to throw lol in the response to you, seemed kinda dikish when I saw it again.
Haha, no worries. I didn't realize you were looking to also power your sub from a multichannel. That's probably a unicorn amp, but would be pretty awesome. I have 100W to each driver up front, which is enough to make my system play cleanly WAY louder than my ears can stand for long, but even bridging two channels to 200W would not be sufficient for my sub.
Reactions: 420tabbycat
Discussion Starter · #12 ·
High probability. The only amp manufacturer I've ever seen that was CEA compliant and did not put out rated power was massive audio.. which leads me to believe they provided a rigged test amp to CEA testers or they are lying and they are not even CEA compliant.
I looked a little closer at it and it seems like it might only work with “their” headunit. There’s no controls on the amp which is cool but I don’t think there’s even a gain.
This is what you’re searching for and someone here had one for sale but decided to keep it. Search the classifieds and who knows?
Discussion Starter · #16 ·
That’s the boss hoss of amps
Personally I would stop trying to only use one amp . If the power supply isnt God you system will suffer . Your subs will starve the rest of the speakers . That Fusion is a piece of trash . Signal to noise is 66db . THD is less than 1% . A good class D will be less than .1% and over 100 on signal to noise . I dont know what your noise issue you had before but this isnt going to help . If you are trying to find one amp to run it all find something with dual power supplies and highs side being class a/b and subs running class D
His noise problems are with feedback between 2 different brands of 4-channel amps, hence the need for 1 8-channel amp.
1 - 20 of 34 Posts
