1 - 20 of 25 Posts
Morel ADMW 9 9" midbassess, 4 ohm
Used. I'd say 8 out of 10. No grills included. Screw marks on the frame around the mounting holes. Morel passive crossovers for use as an add-on kit will be included.
$250 shipped within the US.
Included. See above
These were used in a previous install for about 2 years. I bought them from a member here. You can see from the stickers on the back that 1 looks newer than the other. The newer one was a warranty replacement soon after I bought them due to it being DOA when I received it. A Morel dealer was nice enough to replace it for me under warranty. They were run active as midbasses in the underseat enclosures of my old car.
Will consider trades for Scan 18W (not illuminators) or a small box 10" sub.
excellent midbasses! and pretty shallow at just under 3 inches so they will fit where a lot of the larger diameter woofers wont. glws!
Back to the top.
Would consider trade for some small sealed box 8" subs like Sundown SD2s.
Bringing this back up. Make a reasonable offer so I can get these out of my office corner.
Woofers etc sells these for $550 new. This is a steal for some good midbasses.
The only thing I have to trade is a dd sub
The only sub I'd consider trading for at this point is a Sundown SD3 10. I'm probably going to give the SI BM mkIV I have a try before I decide to abandon it and go smaller but depth is definitely an issue to traditional subs probably won't do.
I have a new pair of Hertz ES 20.5 8" flat subs if you are interested.
Purty. I would love it if i could afford to compare these to my i8's. Other options are so limited given my depth clearence. Did you run them in the doors or sealed?
Discussion Starter #15
They were in under seat enclosures. I wouldn't call them sealed enclosures since they vented into another cavity behind the side skirts. I think those cavities were big enough where this would still be considered IB.
Discussion Starter #18
How well do these play in a small sealed box
I never really tried but remember they are not subs. They are intended to be used as midbasses so don't expect to go low with these. There are other slim 8s that do a better job at sub duty.
How much customization was needed to get them to fit?? I've got a 135i with focal 8" woofers made to fit perfectly under the seats and i'm not impressed with them.
My kicks are sealed running HAT L8's.
Far from ideal I just have to relocate a module on one side and a fuse box on the the other, then open'em up.
1 - 20 of 25 Posts
