So I tried to choose front system here:
http://www.diymobileaudio.com/forum...y-front-system-help-me-un-confuse-choose.html
And I did search.
And now, suddenly I've chosen the Morel kit. The question most on my mind is if I should go 2- or 3-way. I have a VW Passat Variant 2004. I can't touch the instrument panel, I have airbags in the A-pillar, I have no room at my feet, which would leave the door panels for both the mid and mid bass if I go 3-way. Tweeter is in the rear view mirror panel and will stay there. I will post some images later today so you can get a feel for how the interior looks like, and what can be done. The mid will go as close to the rear view mirror panel as possible if I go that way.
Another plan would be to fasten some kind of pod holder in the metal behind the rear view mirror panel for both tweeter and mid (3.5"), but I don't know what it looks like in there as yet.
I would also like to have input in how to mount the 6.5" in the doors. I would like to know the general opinion on what they like the best given their construction and build, not what goes. Is it optimum to have them playing straight into the door or in a closed box? If a closed box, size recommendations? I tried to get some numbers myself but I didn't do that well. 4.25 liters and a Qtc of just below 0.7. I don't even know if this is the way with 6.5" drivers. That size seemed so small.
- My first choice, if doable is to go 3-way because of the larger freedom of choice for the crossing points that I more or less already have decided is the preferred ones, approximately at least.
- I will go active.
- I will add a sub when the front system is finished.
- Amp. will be chosen when I've decided on 2- or 3-way.
- I listen mostly to metal and heavy rock, but I really listen to most genres more or less, if that is pertinent info?
- Please feel free to put in whatever I've forgotten to mention.
- And yes, this is my first project, but that is not an issue here. This is the way I'm going.
And I did search.
- I will go active.
