1 - 8 of 8 Posts
Morel Ultimo 10 $380 shipped (cont. us) including paypal fees
used for 6 months; like new; amazing sq and spl; dont have original box or manual; selling sub only
specs:
# Overall dimensions DxH 263mm (10.53) X 140.3mm (5.52)
# Power handling RMS P 1000 W
# Transient power 10ms 3000 W
# Sensitivity 2.83 Vrms / 1M 87.5 dB
# Sensitivity 1W / 1M 84.5 dB
# Frequency response 10-900 Hz
# Cone material Carbon-fiber laminated paper
# Net weight 6.5 Kg. (14.3 lb.)
# Driver Displacement 2.34 Lit (0.08 cu.ft)
# Voice Coil Diameter 130 mm (5.1)
# Voice coil height 37mm (1.45)
# Voice coil former Aluminum
# Voice coil wire Hexatech Aluminum
# Number of layers 2
# Max. Linear excursion X 12.5mm (0.5) (Each way)
# Magnet system type Double magnet vented
# HE-Magnetic gap height HE 12mm (0.5)
# B flux density B 6.4 T
# BL product BXL 13.0 T.M
# Nominal Impedance Z 4.0 Ohm
# DC Resistance RE 3.7 Ohm
# Voice coil inductance @1KHz LBM 1.0 MH
# Suspension compliance CMS 0.22
# Mechanical Q Factor QMS 1.71
# Electrical Q Factor QES 0.55
# Total Q Factor QTS 0.42
# Mechanical resistance RMS 13.9
# Moving mass MMS 128 gr.
# Eq. Cas air load (liters) VAS 34.5 Lit (1.22 cu.ft)
# Resonant frequency FS 29 Hz
# Effective piston area SD 0.03 m
Soundstream PCX2000D $280 shipped (cont. us)including paypal fees
used for 6 months; new condition; comes with original box, manuals, end caps, etc.
specs:
# RMS Power Ratings:
* 1100 Watts x 1 Channel @ 4 Ohms
* 1500 Watts x 1 Channel @ 2 Ohms
* 2000 Watts x 1 Channel @ 1 Ohm
* 4000 watts max approx.
# TST (Twin Stack Technology): Allows 2 Amps to Drive One Voice Coil!
# High Quality FR-4 Circuit Board
# Class D Circuitry
# Continuously Variable Low-Pass Crossover: 50 - 150 Hz (24 dB/Oct.)
# Continuously Variable Subsonic Filter: 15 - 40 Hz (24 dB/Oct.)
# THD @ Rated RMS Power 0.5%
# Signal-to-Noise Ratio 80 dB
# Variable Subwoofer Equalizer: 0 - 18 dB
# Phase Control: 0° / 180°
# Frequency Response: 5 - 250 Hz
# Adjustable Input Sensitivity: 0.5 - 4V
# Damping Factor: >200
# Fully Regulated MOSFET Power Supply
# PWM Circuitry
# Platinum Power and Ground Connectors
# Accepts up to 16VDC Power Input
# Wire Bass Remote Included
# Dimensions: 10"(W)x2.5"(H)x22.2"(L)
Focal 6w4255 6.5" Mids $160 shipped (cont. us) including paypal fees
Utopia series "W" cone; brand spankin new in box and have never touched power
specs:
100w
4 ohm
1 - 8 of 8 Posts
