1 - 3 of 3 Posts
Hey there,
Researching a diy volume control for Mosconi 6to8v8. The processor has a controller jack which looks to accept a rj12 connector. The pin out diagram is no where to be found. I found a few pics of the board online but cant read it. Does anyone know the pun out config or have decent pic of the board to possibly see the config?
I would also like to confirm that the default for the dial on the controller is for volume control? The manual shows to click the dial to scroll through the other functions, fader, balance, presets.
Since the rj12 has 6 contacts I believe on would be positive and one ground. The remaining four would be for control. Determining which pin is ground has me stumped without taking out my dsp and opening it up.
The only function I am interested in is volume control. Have no need for balance, fader, presets. Thinking a potentiometer would work, or possibly tying into the steering wheel controls if possible.
Reaching out for some help guidance? Is this doable?
Thanks
Discussion Starter #2 (Edited)
Getting closer did a little digging and copied the images off a different website. Now just gotta understand what the heck I am looking out. Since the rj12 is a six-pin connector, and only four pins are needed for volume control, the rj11 connector should work since it has the four pins needed.
Still tinkering with no success. Bought an rj12 cable, 10K pot and an LED. Can get the LED to illuminate but as soon as the pot is turned the LED loses power. I believe the wiring diagram is for an RTC. If that's the case I would need an RTC HUB for the RTC to work with the 6to8v8. Can't find any info on the RTC hub or even a good pic of the board. Here's a link to the thread used google translate. In the meantime, I will keep researching this and typing to myself.
Mosconi Gladen RTC
1 - 3 of 3 Posts
