After doing research on the site and acquiring some equipment from members over the last month, I’ve reached a point where I could use some advice. The vehicle I’m working with is a 2016 BMW 228i convertible.
Here are my goals and parameters:
Thus far, I’ve decided on a three-way active front stage and I’m planning on putting a sub in the trunk. Here’s the equipment I’ve acquired:
So, here are my primary questions:
In any case, having written all of this, I’m recognizing that there are a ton of gaps. I’m a novice here, so I apologize for that. But it is what it is.
Thanks in advance for any advice you have for me!
- Maintain OEM look of the car, including using existing speaker locations and utilizing the driver-side recess in the trunk for the sub to retain space for luggage;
- Retain functionality of HU/Nav controls with the system;
- Attain a good balance of SQ and volume, as this is my daily driver, I’m not going to be entering any competitions, and I like to listen to a variety of music;
- Build a system that is reliable and relatively easy to use, because I’m not a tinkerer (at least, not at this point!);
- Stick to a budget of around $3k, if possible, for remaining equipment and install (originally, I was going to do the install myself, but the more I’ve learned the more I’ve realized that what I want is unachievable given my competence and desired timeline).
- Audiofrog GB 10 (factory location is a sail panel)
- Audiofrog GB 40 (door)
- Audio-Development W800 NEOs for midbass (underseat)
- MMATS Hifi 4250d for the NEOs and a sub
- Should I purchase separate DSP, MOST integration, and Amp, or could I combine one or more of these to save space? I'm intrigued, for example, by the mObridge BMW MOST25 8.1.1, but I recognize that would be overkill when combined with the four channel MMATS.
- If I can combine components, would a Helix P Six DSP MK2 and Helix SDMI25 be a good solution?
- If I should separate all these components, what amps should I consider for the mids and tweets? Stick with MMATS and go for the Hifi 6150D, leaving the possibility of rear fill and an extra sub in the future? Or go with another four channel amp?
- Given separate components and that I’m no expert tuner and won’t be one anytime soon, should I consider the miniDSP with Dirac Live over a Helix DSP? If I’m going to be trusting a pro with the tune, at least initially, what should I give him to work with?
- How should I handle the source? For the sake of portability and simplicity, I’d like to use a streaming service like Tidal and their MQA files. I have an IPhone XR, which I could use. But if there are advantages to having a dedicated player, I’m open to that. What is the simplest way of getting a high quality signal to the DSP while retaining some flexibility, if using a phone or DAP? I’ve seen a variety of threads on the site surrounding these things, and I recognize that not playing lossless files defeats the whole purpose here.
- Sub enclosure and sub? To save space, I’d like to use something like what MusicarNW does with their OE look enclosures, but unfortunately their coupe version (F22) doesn’t fit the convertible (F23). People on the BMW forums have used this guy Visual Ice in the UK, who sells enclosures on Ebay. Perhaps I’m just at the mercy of a local installer who can fabricate a box for me.
- Assuming one of these enclosure is possible, could I run a 12”Audiofrog sub, or would I be limited to a 10"? I believe the space would be sufficient for a sealed enclosure. Are there any advantages, given my amp options above or other possibilities, to running the 2ohm over the 4ohm for the sub?
