1 - 3 of 3 Posts
Going to pass this 2 amp special purchase on to the forum for those interested.... Orders would need to be place within next 24 hrs...
$389.00 + shipping
i believe i only have access to 6 sets.... will try to confirm..
MTX
RT1000D (mono) & RT604 (4 ch.)
RT1000D
Road Thunder Series Monoblock Class D Car Amplifier
RMS Power Rating:
4 ohms: 500 watts x 1 chan.
2 ohms: 1,000 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Patented adaptive class D technology
Dual sided fiberglass printed circuit board
LED power and protect indicators
Smart engage auto turn-on
Mono channel operation
Variable Bass Boost (0 to +12 dB bass boost at 40 Hz)
EBC External bass remote control included
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy convection cooled heatsink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Input sensitivity:
Level: 250mV-5V
Variable low-pass filter (40-200 Hz, 24 dB/octave)
Variable subsonic filter (20-50 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-200 Hz
Dimensions: 17-1/4"L x 7-1/16"W x 2-1/8"H
RT604
Road Thunder Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 60 watts x 4 chan.
2 ohms: 90 watts x 4 chan.
Bridged, 4 ohms: 180 watts x 2 chan.
LED power (green) and protect (red) indicators
Soft Start Turn-on
4/3/2 channel operation
Speaker-level (high-level) inputs with signal sensing for automatic turn-on
Preamp RCA outputs to daisy chain multiple amps
Input sensitivity:
Level: 100mV-6V
Variable high-pass filter (40-400 Hz, 12 dB/octave)
Variable low-pass filter (40-400 Hz, 12 dB/octave)
Frequency response: 20-30,000 Hz
Dimensions: 12-3/16"L x 7-1/16"W x 2-3/16"H
Super Moderator
I really like the understated looks. Also, going by fuse rating they should be more than capable of rated power.
hell, they went quick.. I was only able to get 2... oh well...
1 - 3 of 3 Posts
