Hey all, first post here. To be brief, I'm wondering how you wire multiple grounds. I'm going to be running 5 runs of 1/0 negative, I currently have one, but will need more. It's drilled through a hole in my cabin and into a ground down spot on the frame itself. If I were to introduce multiple grounds, would I just have to make a huge a** drill hole through my cabin and ground them all to the same spot? Could I ground them to my battery? (Battery is closer than the frame ground, it's a cmax behind my passenger rear seat on the floor in an f150).
Any input is appreciated. For reference, I'm going to be running 17,000 or so watts rms through 5 amps. I have distribution blocks and stuff, but that's pointless if there's not an equal amount of wire heading to the frame as to the block.
