Hey everybody, just thought i'd post soem tinkering i've been doing with some rca cables.
I have starting making my own cables using solid core copper wire.
The process involves individually heatshrinking 0.8mm solid copper wire with 2mm heat shrink.
I use 3 strands of wire individually heatshrinked in different colours.
I then braid these 3 heatshrinked wires.
After braiding I solder one rca end on, using silver solder. The red wire is + signal the white wire is - signal and the black is a filler wire that is only connected at one end (the source) to provide limited shielding.
I then slide another black piece of heatshrink about 6mm in size over the wire all the way up to cover the soldered rca.
I then slide the rca cover on and screw together.
I then place the other rca cover onto the wire with another small piece of 6mm heatshrink about 20mm long. I slide this down the wire and out of the way.
I then solder the other rca end on (just the red and white, black left covered by its heatshrink). Slide the smaller 20mm piece of shrink back up and over the solder joins and then slide and screw the rca cover on.
And finished. I made a few of these cables and sent them to some members on the Australian Mobile electronics website and am now awaiting their test results back after using them in their cars.
I will eventailly make the same cables using silver wire instead of copper and see if this yeilds a difference. However still waiting for the first lot to be tested.
In the home environment they work perfectly and sound great however i dont have a working car install to test them myself.
Anyway on with the pics
