1 - 19 of 19 Posts
Will you be upgrading to a solid-state drive, or keeping the mechanical one in there now? I had 3 or 4 drive crashes in the 6-month period I had my car pc, all caused by hitting bumps. At least yours is mounted vertically, which somewhat prolongs the inevitable.
I have two drives horizontally stacked and mounted behind the MB. One is an 40GB SSD for the OS. The other is 720GB 2.5" HD for media.
Mal
Very nice looking. I thought about doing something like that in my last build but I decided to cram it all behind my screen in the dash, so it was completely stealth. I had a 2.5"mechanical harddrive in my car for about 3 years before it finally started to give me issues. This time around I'll definitely use a SSD.
Discussion Starter · #8 ·
Thanks. As a pc tech by trade I know these babies can generate some heat. Thats also why I used the MB Quart case; it had vents already cut in the top. Since I live in Vegas, I wanted to keep it where the a/c can hit it as much as possible. When I limo tint my windows i feel the black cases and low mounting position will help hide it from prying eyes. The low positition will also help w/ heat as cool air falls and warm air rises.
Post some pics of what you got. I would love to check it out.
Mal
I don't have anything as of yet. I had a 8" touchscreen molded to the dash in my mx-3, but I sold that before I moved out here to vegas.
1995 Mazda MX-3 .... 8" Touchscreen in-dash
There are some very very early shots of it. I got rid of the amp and pc below the seat and upgraded to 2 eclipse amps mounted to the back of the seat and a pc behind the lcd.
I'm currently picking out the hardware I want for my new install. It will still be a 8-9" touchscreen. 7" and below is just too small for me. My mx-3 was black exterior and black interior in Florida, so I know about heating issues as well.
very nice :O impressive workmanship.
Discussion Starter · #11 ·
x2. :thumbsup: You did a great job on your first one. The second time around is always easier and better.
This is my first one. I have been working on it for about a year. It would be fully installed if I had not broken my monitor. Hopefully I will get a new one by Christmas.
Mal
Discussion Starter · #14 ·
Are you going to be fabricating it into your dash?
Yeah. That is how I broke the first one. I was mocking up how I was going to mount it after I had just finished the fabrication, when I dropped it. I used the broken one to finalize everything. So when I get my new one I just have to install it.
Mal
Discussion Starter · #16 ·
I'm in process of building one for myself, so thanks for useful ideas!
Your welcome.
Some pointers:
1. I learned that Amplifier dimensions are measured on the outside. So when I picked this amp based on its 2.5" height, I was actually losing about .25-.5" of space inside the case.
2. Wiring can add up and eat up space real fast.
3. Finally, if you want to use add-on audio or video cards, choose a different method to house your motherboard.
Other than that given the opportunity, I'd do it all over again possibly in a Zapco case.
Mal
Have you tested this for any heat related issues? Im just curious because that small of an enclosure seems like you might get some heat issues.
Discussion Starter · #19 ·
No heat related issues at all. I'm using a low (65w) TDP CPU. And even after sitting all day in 100+ degree Vegas heat it boots right up and runs fine.
Mal
1 - 19 of 19 Posts
