Very good working condition, light cosmetic wear from use.
Comes with:
  • Power Harness
  • Aux in and output harness
  • Remote
Located just outside of Toronto, Buyer pays shipping.
Specs:
  • 24-bit D/A converter
  • 4 illumination options
  • Remote Control
  • CD-R/CD-RW compatible
  • High power 47 watt x 4 amplifier
  • 3 Sets of Pre-Outs (Front, Rear, and Subwoofer)
  • Adjustable subwoofer output (adjustable +/- 10 db, Off)
  • Amplifier section
    Maximum Power Output 47 W x 4 (4ohms)
    Frequency Response 15 - 30,000 Hz &,1 dB
    Total Harmonic Distortion 0.1%
    (4 ohms. 1 kHz, 3 WR 4)
    AUX Input Level/Impedance 1 V/50 kohms
    Output Level 4 V
  • Tone Controls
    Bass 100 Hz 211 dB
    Mid 1 kHz +11 dB
    Treble 10 kHz 211 dB
    Loudness 20 Hz +14 dB (Volume level 20)
  • FM tuner Section
    Frequency Range
    U.S.A. 87.5 - 107.9 MHE in 100-kHE steps
    01her Area 87.5 - 108.0 MHz in [email protected] steps
    Sensitivity 15dBf(lHF)
    Signal-to-Noise Ratio 60 dB (Morse)
    Stereo Separation 35 dB
    Antenna input 75 ohms (Unbalanced)
  • AM tuner section
    Frequency Range
    U.S.A. 530 - 1,7 10 kHz in 10-kHz steps
    Other Area 531 - 1,602 kHz in 9-kHz steps
    Sensitivity 32 dB
    Signal-to-Noise Ratio 45 dB
  • CD player section
    System Compact Disc digital audio
    Error Correction CIRC Principle
    Sampling Frequency 44.1 kHz
    DIA Converter Type 24-bit O/A converter
    Frequency Response 20 - 20,000 Hz
    Signal-to-Noise Ratio Better than 100 dB
    Dynamic Range Better than 90 dB
    Total Harmonic Distortion 0.005% (1 kHz)
  • General
    Power Source 14.4 V DC, negative ground
    (10.8 - 15.6 V allowable)
    Current Consumption 9.0 A (At rated power output)
    Installation dimensions 178 Rx 50 (H) x 158 (D) mm
    7 (W) x 1-15/18 (H) x 8-1/4 (D) inches
    Outer dimensions 178 (W) x 50 (H) x 170 (D) mm
    7 (W) x 1-15/16 (H) x8-11/16 (D) inches
    Mass Approx. 1.5 kg / 3 lbs. 5 oz.
  • Remote control unit
    Principle Infrared pulse system
    Power Supply 3 V DC (1.5 V x 2)
    Dimensions 49 (W) x26 (H) x 110 (0) mm
    1-15/16 (W) x 1 (H) x 4-5/16 (D) inches
    Mass Approx. 60 g / 2 oz.
[TD]​
[TD][/TD]​
[/TD]
