1 - 17 of 17 Posts
I took the dive and purchased some new Nakamichi equipment try out. By doing so I had to buy multiples of certain items. I have two n40t, one I am keeping for myself, and the other here in the listing for sell. The MSRP is $1,599.95 however I am just wanting to get what I have in it or as close to the original amount back. These are a low production series, this one is number 182. I have unpacked it to make sure it is 100%, has not been used. Please pm me if you have any questions. $1,125 + shipping.
  • N-power Output @4Ω: 150Wx4
  • N-power Output @2Ω: 225Wx4
  • Bridge Output @4Ω: 450Wx2
  • Frequency Response: 10Hz-25kHz
  • Input Sensitivity: 200mV to 6V
  • Signal To Noise Ratio: ≥90dB
  • T.H.D.: ≤0.2%
  • Low Pass Cross Frequency: 50Hz-500Hz
  • Bass Boost: 0dB-12dB
  • Remote Subwoofer Level: No
  • Minimum Impedance: 20K
  • Fuse Size: 30Ax4
  • Net Weight: Approx. 5.0kg
  • Dimensions (LxHxW): 476x214x60mm
274359
274360
274361
274362
274363
274364
274365
2006 Mazdaspeed6; 2003 Chevy Avalanche WBH
Wow!! Nakamichi and tubes!! I wish I had the funds!!!
Sent from my GM1915 using Tapatalk
How does it sound and is it comparable to anything?
So far I am impressed with the one I am using. Its hard to explain the sound. I will listen to piano, jazz etc when trying to compare products, essentially music where it is easier to hear differences. I have been comparing it to an Arc Audio SE I have on the bench using Audison AVK6 speakers. It has just as much detail and dynamics as the Arc with a warmer presentation to it, very hard to explain. The build quality is very nice, the controls are laid out well and the controls them self feel solid. There is also a direct dsp option which bypass the crossover as well as gain on the amplifier.
That thing rivals the old school Diamond Audio amps for beauty. Hubba hubba!
Sent from my SM-G950U using Tapatalk
Discussion Starter #13
Very sleek looking amplifier, well thought out. It has active fan cooling and it has a hidden vent around the Nakamichi badge where the hot air exhausts. Whoever designed it put a lot of detail into it.
1 - 17 of 17 Posts
