1 - 10 of 10 Posts
Pxa-h701 power cable/harness
New,used
Tbd
Negotiable
Discussion Starter #2
Or if someone has detailed close up pictures I have Molex plugs and the correct pins to make a harness. Nobody has one in stock except for a guy on eBay from the UK. I'D rather not wait until late May or early June to receive it.
Also the Mic for time alignment and level settings. Will the imprint audyssey mic or the pxa-h800 mic work? Just picked one up cheap but is missing cables.
If I remember correctly, some of the old Sirius brains used the same plug, though I can't remember if the wiring was the same. Does Pac Parts have any?
I made one with the help of a forum member already, but thank you. One thing I need to know though is what amperage fuse should I put on the yellow power line. I just put a 10 in it, but would like to make sure I have the correct fuse installed
And if anyone has a rux-c700 they would like to sell please pm me.
The deck I have controls it just fine, but according to my decks manual some of the features need to be turned on or off with the rux to be controlled at the head unit (ina-w910). So turns out you do kind of need a rux, even with a double din deck that has full control
1 - 10 of 10 Posts
