1 - 5 of 5 Posts
The factory HU in my 2011 4Runner does not seem to have a switched output. I am running an Audio Control LCQ-1 and it comes on as soon as the key is on. I'd rather have it controlled by the HU on & off. I've played with the LCQ-1s internal jumper with no success.
Is there an aftermarket circuit / switch I can use to switch the LCQ-1 & Amp
on & off with the HU ?
Moderator
Your best bet would probably be go to the ignition harness or driver's kick panel if it's a PTS truck and grab an accessory.
I don't think an accessory feed will turn on & off with the radio. As I have it now, the processor & amp stay on as long as the ignition switch is on.
there is no way to do what you are saying. if the radio has no remote output then you cant have the radio turn on the amplifiers. you only have two choices
1) put in a switch to turn the processors/amplifiers manually.
2) put in a PAC TR7 to delay the turn on so the HU has time to come on first.
1 - 5 of 5 Posts
