hey all so im planning out my system in my bmw e90, so ive got a question for yall. my car apparently can only use amps that accept a balanced differential input, which obviously makes planning harder. if im going directly from the jbl ms8 to amps then onto the speakers, will i still need that type of amp?? or can i use whatever amp i want?
thnx all!!
How is the signal transferred from OEM HU to MS8? Seems to me if you can successfully get the signal to the MS8, then you are home free to use any am you wish.
its an analog signal approx 5v, im just pulling the oem amp and technically replacing it with the ms8, i think i attached the diagram of what im working with.
You can use whatever amp you want. The MS-8 will convert that balanced signal and output it's own traditional unbalanced single-ended RCA signal. It's analog input and output stages are isolated by the digital domain of the DSP so one has nothing to do with the other.
