1 - 20 of 120 Posts
I want to pair them with dyn tweet and 3" mid. Listen mostly to hip hop. Cost no object.
I need some oppinions.....researching spec's all day and night is getting boooooring. So real world experience would help a lot.
Thanks folks.
morel supremos
scanspeak illuminators
Dynaudio esotar 6
those are a good start
i just got some morel hybrid ovation, mids i will see how they sound, im going to try to put them in today
do u have a budget? how much power for them? how much air space? what type of install? do a "6.5 midbass" search. i did this and got 15 pages of hits. u will find the info u seek there.
Discussion Starter · #7 ·
Thanks, guys, for the suggestions. It is the real world experience I'm after. And esspecially for the mid bass. I've had a two way active for years and had many drivers that reproduced the mid range well. But I have no experience in a three way set up where the 6.5 is primaraly used for midbass.
As for where it would go, it would be in a factory door pannel, I don't want to make a new pannel. I'm finally stepping into a lux ride, so I'm keeping it stock for the first couple years. Going to power them with a VRX 6.420 with around 100 watts to them.
P.S. - The doors will be preped properly....sound deadening, baffle, etc.
What about the SLS 6.5's?
if you're going 3 way this is what i would do. the SLS is almost like a small sub as they only play up to 800hz flat but they should give you the up front thump you need. they come in 8'' too.
Thanks folks.
The "tightness" of bass has more to do with the frequency response than the manufacturer. I can make a $10 woofer sound "tighter" than a $500 woofer that doesn't have the correct set of parameters.
So don't get caught up in the brand.
If anyone cares I can post some info on what parameters are required for "tight bass."
I'm interested.
Please do Patrick...
If you're going three-way up front, I suggest just looking for the 6.5" driver with the most Vd (Sd*Xmax), and deal with the rest via EQ, x-over, TA and enclosure treatment. Midrange performance won't be an issue, because you won't be using it for that. That approach should cut down your list of options by quite a bit.
1 - 20 of 120 Posts
